| » kitchen Aid no water on rinse cycle |
Model Number: KUDU02FR Brand: Kitchen Aid Age: 1 - 5 years
My Kitchen Aid dishwasher model number KUDU02FR that will not fill with water in any cycle including "rinse only", so I do not think there is a problem with the fill valve. Any suggestions?
Open the door and make sure the float (#15 at the diagram) is in the lowest possible position.
Remove the toe panel and check the float switch (#11) for continuity. Normally it should be closed. Remove the wires from the water inlet valve and check for 120 VAC between them while the control calls for water. Post the results. The model number you posted is incomplete. Verify and repost it please. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| only spin cycle and drains. no agitate, water fill or rinse cycle | reyd1 | Washer Repair | 0 | 07-01-2012 07:40 AM |
| No water in rinse cycle | smnweisen | Washer Repair | 3 | 06-25-2012 09:56 PM |
| Washer only fills with hot water, no water during rinse cycle | rcmedrec1 | Washer Repair | 1 | 08-05-2011 06:28 PM |
| Water fill is delayed, must wait to have water in rinse cycle | sewsmack | Washer Repair | 0 | 10-19-2010 02:45 PM |
| Kitchen Aid Washer won't go into rinse cycle | jaydfla | Washer Repair | 1 | 08-08-2008 08:02 PM |
