Discuss
repair or repair circulator pump
 in
Dishwasher Repair
The above has worked without fail until last night when the pump continued to run all night long. When discovered
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » repair or repair circulator pump
  #1 (permalink)
Old 11-12-2012, 10:29 PM
Junior Member
culkj is on a distinguished road
Default repair or repair circulator pump
Model Number: SHU5312UC/06   Brand: Bosch   Age: More than 10 years
The above has worked without fail until last night when the pump continued to run all night long. When discovered this morning there was a slight burnt electric smell, but the pump was still running. Circuit breaker never tripped.
The appliance repair man found about 1/2 gal. of water in the tray below the unit, sucked it dry, and started the machine. the leak is near the pump in the right front corner of the machine which is connected to a large white plastic assembly. The leak is at the junction of pump/fitting.
The repairman referred to the problem part as the "wash motor" but I believe it is actually a "circulator pump". I can send a pictureif it will help.
Questions for the experts here.
There is also a drain motor. what's the likelihood this is at fault/involved. On a cold start the unit runs for a few seconds pumping water with no sign of leaking until fresh water valve opens and the wash cycle starts.
The viable leak is right at the seam between the motor and the impolite housing. Given that the motor definitely got hot enough to give off burnt electric smell, but seems to run fine your thoughts on a repair kit vs replacing the whole pump assembly. Given the units age, and the cost of the pump, I'm hoping for the low cost option.
Thanks in advance for any and all help.
Jack
Ads By Google
Related Models
Bosch SHU5314 UC/06
Bosch SHU5314 UC/11
Bosch SHU5314 UC/12
Bosch SHU5315 UC/06
Bosch SHU5315 UC/06 (FD 7705-7912)
Bosch SHU5315 UC/11
Bosch SHU5315 UC/11 (FD 8001-8003)
Bosch SHU5315 UC/12
Bosch SHU5315 UC/12 (FD 8003-)
Bosch SHU5316 UC/06
Bosch SHU5316 UC/11
Bosch SHU5316 UC/12
Bosch SHU5317 UC/12
Bosch SHU53A02 UC/14 (FD 8211-)
Bosch SHU53A05 UC/14 (FD 8211-)
Bosch SHU53A06 UC/14 (FD 8211-)
Bosch SHU53E02 UC/14 (FD 8211-)
Bosch SHU53E05 UC/14 (FD 8211-)
Bosch SHU53E06 UC/14 (FD 8211-)
Whirlpool SHU55000
Whirlpool SHU55010
Whirlpool SHU55040
Whirlpool SHU55041
Whirlpool SHU55042
Whirlpool SHU60010
Whirlpool SHU60011
Whirlpool SHU60020
Bosch SHU66C02 UC/14 (FD 8211-)
Bosch SHU66C05 UC/14 (FD 8211-)
Bosch SHU66C06 UC/14 (FD 8211-)
Bosch SHU66C07 UC/14 (FD 8211-)
Bosch SHU66E02 UC/14 (FD 8211-)
Bosch SHU66E05 UC/14 (FD 8211-)
Bosch SHU66E06 UC/14 (FD 8211-)
Bosch SHU66E07 UC/14 (FD 8211-)
Bosch SHU6802 UC/06 (FD 7705-7912)
Bosch SHU6802 UC/11 (FD 8001-8003)
Bosch SHU6802 UC/12 (FD 8003-)
Bosch SHU6805 UC/06 (FD 7705-7912)
Bosch SHU6805 UC/11 (FD 8001-8003)
Bosch SHU6805 UC/12 (FD 8003-)
Bosch SHU6806 UC/06 (FD 7705-7912)
Bosch SHU6806 UC/11 (FD 8001-8003)
Bosch SHU6806 UC/12 (FD 8003-)
Whirlpool SHU70000
Whirlpool SHU70001
Whirlpool SHU70010
Whirlpool SHU70040
Whirlpool SHU70041
Whirlpool SHU70050
Whirlpool SHU70051
Whirlpool SHU70052
Whirlpool SHU75000
Whirlpool SHU75010
Whirlpool SHU75040
Whirlpool SHU75042
Whirlpool SHU80000
Whirlpool SHU80001
Whirlpool SHU80010
Whirlpool SHU80040
Whirlpool SHU80041
Whirlpool SHU80042
Bosch SHU8802 UC/12 (FD 8105-)
Bosch SHU8805 UC/12 (FD 8105-)
Bosch SHU8806 UC/12 (FD 8105-)
Bosch SHU8812 UC/12 (FD 8105-)
Bosch SHU8815 UC/12 (FD 8105-)
Bosch SHU8816 UC/12 (FD 8105-)
Whirlpool SHU90000
Whirlpool SHU90001
Whirlpool SHU90002
Whirlpool SHU90010
Whirlpool SHU90040
Whirlpool SHU90041
Whirlpool SHU90050
Whirlpool SHU99000
Whirlpool SHU99001
Bosch SHU9902 UC/06
Bosch SHU9902 UC/06 (FD 7905-7912)
Whirlpool SHU99040
Whirlpool SHU99041
Bosch SHU9905 UC/06
Bosch SHU9905 UC/06 (FD 7905-7912)
Whirlpool SHU99050
Whirlpool SHU99052
Whirlpool SHU99053
Bosch SHU9906 UC/06
Bosch SHU9906 UC/06 (FD 7905-7912)
Bosch SHU9912 UC/06
Bosch SHU9912 UC/06 (FD 7908-8002)
Bosch SHU9912 UC/11
Bosch SHU9912 UC/11 (FD 8002-8003)
Bosch SHU9912 UC/12
Bosch SHU9912 UC/12 (FD 8003-)
Bosch SHU9915 UC/06
Bosch SHU9915 UC/06 (FD 7908-8002)
Bosch SHU9915 UC/11
Bosch SHU9915 UC/11 (FD 8002-8003)
Bosch SHU9915 UC/12
Bosch SHU9915 UC/12 (FD 8003-)
Bosch SHU9916 UC/06
Bosch SHU9916 UC/06 (FD 7908-8002)
Bosch SHU9916 UC/11
Bosch SHU9916 UC/11 (FD 8002-8003)
Bosch SHU9916 UC/12
Bosch SHU9916 UC/12 (FD 8003-)
Bosch SHU9922 UC/12 (FD 8003-)
Bosch SHU9925 UC/12 (FD 8003-)
Bosch SHU9926 UC/12 (FD 8003-)
Bosch SHU9952 UC/12 (FD 8105 -)
Bosch SHU9955 UC/12 (FD 8105 -)
Bosch SHU9956 UC/12 (FD 8105 -)
Bosch SHV4303 UC/06
Bosch SHV4303 UC/06 (FD 7712-8002)
Bosch SHV4303 UC/11
Bosch SHV4303 UC/11 (FD 8002-8003)
Bosch SHV4303 UC/12
Bosch SHV4303 UC/12 (FD 8003-)
Bosch SHV46C03 UC/14 (FD 8211-)
Bosch SHV4803 UC/06
  #2 (permalink)
Old 11-13-2012, 08:32 AM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
You paid a tech to come look at it and now your asking us how to repair it? What did the tech that looked at it suggest? Just wondering...
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 11-13-2012, 08:46 AM
Junior Member
Default
Good question. He suggested replacing the "wash motor" assembly as a unit as no rebuild kids were available. Did not have parts, but estimated between $500-600 to replace. When I found that a rebuild kit is available for under $100 it raised the options I asked for help on here. I'm comfortable with the work and Gabe the time.
Thanks got the reply. Would appreciate any following thoughts you and/or others might have.
Jack
  #4 (permalink)
Old 11-13-2012, 08:49 AM
Junior Member
Default
Sorry for the typos. Doing this on my phone as I can't access the message frame on my PC browser.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
drain pump repair azcowboy Washer Repair 1 01-10-2012 06:53 AM
washer pump out repair kimandrobon@gmail.com Washer Repair 0 12-29-2011 01:30 PM
Dishwasher Pump Repair? jjtsai Dishwasher Repair 0 03-26-2011 03:39 PM
pump repair ronaldsands Washer Repair 1 01-30-2009 06:25 PM
drain pump repair gibsonhelp Washer Repair 4 01-05-2009 01:43 AM
