| » Dishwasher will wash but not drain |
Model Number: HDA1200G00BB Brand: Hotpoint Age: 1 - 5 years
My dishwasher will wash but cuts off when the drain cycle starts. I have already replaced the air gap (thought that it might be clogged but it wasn't). Is there another hose that might be clogged?
Hi.
Remove the toe panel and observe the drain cycle.With the timer set to drain the drain solenoid on the left of the pump/motor should energize and retract, redirecting the water flow to the drain hose. If that happens you need to check the drain hose for any obstructions. If it doesn't - use the multimeter to check for 120VAC at the solenoid (with the timer set for drain). Here are the breakdown diagrams and http://www.appliancepartspros.com/03...1200g00bb.html Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
I had the same problem. The dishwasher would run, and at the end of the cycle there was water still inside the machine. I'm not an appliance expert, but I just went through some troubleshooting. You said you disconnected the hose from the sink to the bucket on the dishwasher. I did the same thing and took a video of doing it because apparently its a common problem. I think in your case, the hose isn't clogged between the sink and machine, but rather after the sink. If you have a food disposer, or even in the absence of it, I often found that accumulation of the machines byproducts became adherent after the hose-sink junction. I disconnected all of them, and it was clear that one part in the networking of the hoses was more prone to byproduct accumulation and clogging. The clog was white in color and tough. This stuff builds up over time, almost like someone's artery, and once clogged, your best bet is to throw it out, and get a new hose. Its a cheap solution, and is usually the cause. 30,000 ppl watched my video on dishwasher repair, and a lot of them reported the same issue and solution. My "how to" video on dishwasher repair may help. I used someone else's video when I approached this issue, and the videos helped... Here it is. Goodluck!:
https://www.youtube.com/watch?v=u7uaA2NZKl0 I do have a question, forget the arm in the bottom, because that's unlikely. Believe it or not, its not usually food clogging it up, but rather the soaps. Is your machine older than 2 yrs? Read more: dish washer does not drain completely http://forum.appliancepartspros.com
__________________
All Appliances I fix, Plus Humans |
| Display Modes | |
| Old GE Dishwasher doesn't wash or drain | Jeffers | Dishwasher Repair | 3 | 10-12-2010 09:01 AM |
| Dishwasher will not drain/continue wash. | debbie@wlxr.com | Dishwasher Repair | 0 | 06-29-2010 03:06 PM |
| Dishwasher fills, won't wash or drain | DanielH | Dishwasher Repair | 0 | 10-19-2009 04:19 PM |
| Whirlpool dishwasher won't wash, but will drain | ed3120 | Dishwasher Repair | 0 | 08-03-2009 10:18 AM |
| Dishwasher cycles but no wash/drain | bmagis | Dishwasher Repair | 6 | 07-17-2009 10:54 AM |
