| » Dishwasher fills, runs 30 seconds, drains, repeats |
Model Number: ADW1100N00WW Brand: Admiral Age: 1 - 5 years
Dishwasher fills with water, starts to run, spray water, then after 30 seconds to a minute stops and drains, then repeats this cycle. Didn't run full normal cycle, started and after 3-5 minutes it had ran 3 of these cycles.
Remove the toe panel and check the drain solenoid on the left side of the pump. Very likely it is stuck open.
If it is and it's melted, replace the solenoid and the timer. If it's not melted, replace just the solenoid. - The drain solenoid & bracket Part number: WD21X10268 - The armature & linkage Part number: WD1X1316 - The timer Part number: WD21X10350 Here are the breakdown diagrams and Parts for GE ADW1100N00WW Dishwasher - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Pulled lower panel and watched today after tech reply. To start the solenoid and arm are in the up position. Machine will run a drain cycle, at the end of cycle approx 30 seconds, solenoid will buzz and the arm drops down, maybe 10 seconds. Next the solenoid releases back to the up position and the machine fills, then agitates thew water for about a minute or so. Process is repeated by machine.
Since solenoid is working is the a way to test or would it be locked into place if bad? If solenoid is good, then where do I look? Hotpoint ADW1100N00WW |
Per your description the timer is bad and has to be replaced.
__________________
| Display Modes | |
| Washer fills, waits, drains,repeats | WEASEL36 | Dishwasher Repair | 3 | 10-04-2012 12:03 PM |
| Dishwasher fills and tries to run but doesn't. Still drains | formflier | Dishwasher Repair | 0 | 08-30-2011 10:09 PM |
| Bosch dishwasher fills, drains, fills again then stops | ricsan | Dishwasher Repair | 1 | 06-05-2008 03:40 AM |
| Fills+drains pump runs but wash arms not moving | aace73 | Dishwasher Repair | 3 | 02-07-2008 06:15 PM |
| Dishwasher fills and drains and runs trough cycles but doesnt wash | ryan6663 | Dishwasher Repair | 1 | 10-24-2007 04:11 PM |
