Discuss
Whirlpool drain leaks when filling with water...
 in
Dishwasher Repair
I just bought a used d/w that appears to be cycling and working fine except the drain does not completely
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool drain leaks when filling with water...
  #1 (permalink)
Old 11-06-2012, 01:16 PM
Junior Member
Poodlehead is on a distinguished road
Default Whirlpool drain leaks when filling with water...
Model Number: DU850DWGB1   Brand: Whirlpool   Age: 5 - 10 years
I just bought a used d/w that appears to be cycling and working fine except the drain does not completely seal. After 5-10 seconds of filling with water, the drain starts dribbling, almost a steady stream... The washer washes, but then runs out of water before the cycle should end so I"m assuming it will not wash dishes worth a flip.
I removed the drain valve cover and inspected the diaphragm. It is soft and does not have any holes in it. I can also see where the round seat imprint is in the middle, so I think it is OK. Maybe it shouldn't be so soft and pliable?
Thanks for any suggestions!
Pat
Ads By Google
Related Models
Whirlpool DU850DWGB1
Whirlpool DU850DWGQ0
Whirlpool DU850DWGQ1
Whirlpool DU850DWGX0
Whirlpool DU850DWGX1
Whirlpool DU850SWKB0
Whirlpool DU850SWKQ0
Whirlpool DU850SWKT0
Whirlpool DU850SWLB0 Undercounter Dishwasher
Whirlpool DU850SWLQ0 Undercounter Dishwasher
Whirlpool DU850SWPB0 Undercounter Dishwasher
Whirlpool DU850SWPB1 Undercounter Dishwasher
Whirlpool DU850SWPB2 Undercounter Dishwasher
Whirlpool DU850SWPB3 Undercounter Dishwasher
Whirlpool DU850SWPQ0 Undercounter Dishwasher
Whirlpool DU850SWPQ1 Undercounter Dishwasher
Whirlpool DU850SWPQ2 Undercounter Dishwasher
Whirlpool DU850SWPQ3 Undercounter Dishwasher
Whirlpool DU850SWPS0 Undercounter Dishwasher
Whirlpool DU850SWPS1 Undercounter Dishwasher
Whirlpool DU850SWPS2 Undercounter Dishwasher
Whirlpool DU850SWPS3 Undercounter Dishwasher
Whirlpool DU850SWPT1 Undercounter Dishwasher
Whirlpool DU850SWPT2 Undercounter Dishwasher
Whirlpool DU850SWPT3 Undercounter Dishwasher
Whirlpool DU850SWPU0 Undercounter Dishwasher
Whirlpool DU850SWPU1 Undercounter Dishwasher
Whirlpool DU850SWPU2 Undercounter Dishwasher
Whirlpool DU850SWPU3 Undercounter Dishwasher
Whirlpool DU851SWPS0 Undercounter Dishwasher
Whirlpool DU851SWPS1 Undercounter Dishwasher
Whirlpool DU851SWPS2 Undercounter Dishwasher
Whirlpool DU8530XX0
Whirlpool DU8530XX1
Whirlpool DU8550XB0
Whirlpool DU8550XB1
Whirlpool DU8550XT0
Whirlpool DU8550XT1
Whirlpool DU8550XT2
Whirlpool DU8550XT3
Whirlpool DU8550XT4
Whirlpool DU8550XT5
Whirlpool DU8550XX0
Whirlpool DU8550XX1
Whirlpool DU8550XX3
Whirlpool DU8550XX4
Whirlpool DU8560XB0
Whirlpool DU8560XB1
Whirlpool DU8560XX0
Whirlpool DU8560XX1
Whirlpool DU8560XX2
Whirlpool DU8570XT0
Whirlpool DU8570XT1
Whirlpool DU8570XT2
Magic Chef DU85CA-01 Dishwasher - Undercounter
Magic Chef DU85CA-02 Dishwasher - Undercounter
Magic Chef DU85CA-20 Dishwasher - Undercounter
Magic Chef DU85DA-25 Dishwasher - Undercounter
Magic Chef DU85DA-35 Dishwasher - Undercounter
Magic Chef DU85DA-45 Dishwasher - Undercounter
Magic Chef DU85DA-48 Dishwasher - Undercounter
Magic Chef DU85DN-35 Dishwasher - Undercounter
Whirlpool DU860SWSB0 Undercounter Dishwasher
Whirlpool DU860SWSQ0 Undercounter Dishwasher
Whirlpool DU860SWSS0 Undercounter Dishwasher
Whirlpool DU8700XB0
Whirlpool DU8700XB1
Whirlpool DU8700XT0
Whirlpool DU8700XT1
Whirlpool DU8700XT2
Whirlpool DU8700XT3
Whirlpool DU8700XT4
Whirlpool DU8700XT5
Whirlpool DU8700XX0
Whirlpool DU8700XX1
Whirlpool DU8700XY0
Whirlpool DU8700XY1
Whirlpool DU8700XY2
Whirlpool DU8700XY4
Whirlpool DU8700XY5
Whirlpool DU8720XX0
Whirlpool DU8750XB0
Whirlpool DU8750XB1
Whirlpool DU8750XT0
Whirlpool DU8750XT1
Whirlpool DU8750XT2
Whirlpool DU8750XT3
Whirlpool DU8750XY0
Whirlpool DU8750XY1
Whirlpool DU8770XB0
Whirlpool DU8770XB1
Whirlpool DU8770XX0
Whirlpool DU8770XY0
Whirlpool DU8770XY1
Whirlpool DU8770XY2
Whirlpool DU8900XB0
Whirlpool DU8900XB1
Whirlpool DU8900XL0
Whirlpool DU8900XT0
Whirlpool DU8900XT1
Whirlpool DU8900XT2
Whirlpool DU8900XT3
Whirlpool DU8900XT4
Whirlpool DU8900XT5
Whirlpool DU8900XT6
Whirlpool DU8900XY0
Whirlpool DU8900XY1
Whirlpool DU8900XY2
Whirlpool DU8903XL0
Whirlpool DU890DWGQ0
Whirlpool DU890DWGQ1
Whirlpool DU890DWGQ2
Whirlpool DU890DWGU2
Whirlpool DU890DWGX0
Whirlpool DU890DWGX1
Whirlpool DU890DWGZ0
Whirlpool DU890DWGZ1
Whirlpool DU890DWGZ2
Whirlpool DU890SWKQ0
Whirlpool DU890SWKT0
  #2 (permalink)
Old 11-06-2012, 09:08 PM
Junior Member
Default
I had the luxury to run the test on another d/w that is known good and is the exact same model number and it did the exact same thing. I've guess there must be some sort of back flow pressure required on the discharge hose to seal the drain valve. Does that make sense? Thanks in advance!
  #3 (permalink)
Old 11-07-2012, 01:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Pat,
Where and how the drain hose is connected to?
Here are the breakdown diagrams and Parts for Whirlpool DU850DWGB1 Dishwasher - AppliancePartsPros.com
The installation instructions might help you to verify the drain hose connection.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #4 (permalink)
Old 11-07-2012, 06:43 PM
Junior Member
Default
Hi Gene,
I did not have the dishwasher installed. It was sitting in the back of my truck with the garden hose connected to the water valve. I just had a 90 degree plastic pipe taped to the drain outlet at the front of the d/w so it would just run on the ground. I plugged the loose wires into the end of an extension cord to run it through the cycles... Since both d/w's did the same thing (leaked out the drain pipe once enough water was inside the cabinet), I'm guessing the other end of the drain hose does need to be connected to allow the diaphragm to seal? Does that make sense and if so, can you please 'splain' why? Thank you! Pat
  #5 (permalink)
Old 11-09-2012, 05:22 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
... I've guess there must be some sort of back flow pressure required on the discharge hose to seal the drain valve...
This is correct. The drained water must go up at least 20" above the floor level and then it can go down.
Quote:
...It was sitting in the back of my truck with the garden hose connected to the water valve...
I'm assuming you did it for test only. Otherwise it will never clean dishes because of water temperature which must be at least 120°F.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet leaks water Richaong Washer Repair 4 02-14-2012 07:14 PM
Whirlpool Washer stopped after filling with water tgeast56 Washer Repair 1 01-10-2012 10:16 AM
Whirlpool washer leaks from front while filling bobandjayne Washer Repair 3 04-28-2011 01:46 PM
washer will start filling with water and just drain never started next cycle shannon12 Washer Repair 1 04-07-2011 01:42 PM
Water does not stop filling and leaks kanabcab Washer Repair 8 03-02-2010 05:01 PM
