Discuss
Maytag Dishwasher stops after wash mode
 in
Dishwasher Repair
Just want to share my successful fix with others! Read this before you do something expensive like replacing your timer/control
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Maytag Dishwasher stops after wash mode
  #1 (permalink)
Old 11-03-2012, 01:21 PM
Junior Member
kshinhale is on a distinguished road
Smile Maytag Dishwasher stops after wash mode
Model Number: MDB-5 Quiet-Series-200   Brand: Maytag   Age: 5 - 10 years
Just want to share my successful fix with others! Read this before you do something expensive like replacing your timer/control panel!!! Dishwasher was stopping after the wash mode with the lights on control panel going out. There was still water in bottom of dishwasher but it seemed to drain if I pushed the CANCEL button. I first thought something was messed up in the timer or control mechanism and tried reseting the circuit breaker...no help...when I started it up again the same thing happened. Pressed CANCEL to drain it again and then removed the spinner arm from the bottom of dishwasher and continued with the removal of each subsequent part beneath the spinner arm. (As a novist, I take care to line up the parts in reverse-order so that re-assembly is a piece of cake!) When I got all the parts off, I discovered that the dishwasher had not actually drained completely. I tried snaking out the drain but couldn't get past the first bend. Next I tried sucking it out with a turkey baster (it's a girl thing !) when my son walked in and suggested I try his shop vac. Be sure to take the filter out of your shop vac as you will be sucking out water. Place the hose end tightly over the drain hole (do your best to create a seal), turn on the vac and suck away. I did it 3 times until I no longer heard the water and sludge comming thru the hose...this is what I call REVERSE DRAIN CLEANING! It worked like a charm. When I put the unit back together and started it up, it all worked perfectly normal. So before you think you need an expensive part like a timer, make sure your drain is clear....apparently the timer will shut down and not proceed to the next cycle if the water is not draining properly. Hope your repair goes as well as mine, Novist Karen
Ads By Google
Related Models
Frigidaire MDB100RGD0 Frg(v1) / Refrigerator
Frigidaire MDB100RGW0 Frg(v2) / Refrigerator
Frigidaire MDB100RGW1 Universal/dishwasher
Frigidaire MDB110LGW0 Frg(v0)
Frigidaire MDB120LGR0 Frg(v0) / Refrigerator
Frigidaire MDB120RFM0 Frg(v1) / Built - in Dishwasher
Frigidaire MDB120RFM1 Frg(v1) / Built - in Dishwasher
Frigidaire MDB120RFM2 Frg(v0) / 24 " Built - in Dishwasher
Frigidaire MDB120RFM3 Frg(v0) / 24 " Built - in Dishwasher
Frigidaire MDB121GFR0 Frg(v0) / Built - in Dishwasher
Frigidaire MDB121GFR1 Frg(v0) / Built - in Dishwasher
Frigidaire MDB121GFR2 Frg(v0) / 24 " Built - in Dishwasher
Frigidaire MDB121RFM0 Frg(v2) / Built - in Dishwasher
Frigidaire MDB121RFM1 Frg(v2) / Built - in Dishwasher
Frigidaire MDB121RFM2 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire MDB121RFS0 Frg(v3) / Built - in Dishwasher
Frigidaire MDB121RFS1 Frg(v3) / Built - in Dishwasher
Frigidaire MDB121RFS2 Frg(v2) / 24 " Built - in Dishwasher
Frigidaire MDB122LBS0 Universal/dishwasher
Frigidaire MDB122LBS1 Universal/dishwasher
Frigidaire MDB122RFS0 Frg(v0) / Dishwasher
Frigidaire MDB122RFS1 Dishwasher
Frigidaire MDB122RFS2 Universal/dishwasher
Frigidaire MDB124BAB0 Universal/dishwasher
Frigidaire MDB124BAB1 Universal/dishwasher
Frigidaire MDB124BAS0 Universal/dishwasher
Frigidaire MDB124BAS1 Universal/dishwasher
Frigidaire MDB124BFR0 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire MDB124BFR1 Frg(v2) / 24 " Built - in Dishwasher
Frigidaire MDB124BFR2 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire MDB124BFS0 Frg(v3) / 24 " Built - in Dishwasher
Frigidaire MDB124BFS1 Frg(v4) / 24 " Built - in Dishwasher
Frigidaire MDB124BFS2 Frg(v2) / 24 " Built - in Dishwasher
Frigidaire MDB124BFS3 Frg(v0) / Refrigerator
Frigidaire MDB124BHS0 Frg(v0) / Refrigerator
Frigidaire MDB124BHS1 Universal/dishwasher
Frigidaire MDB124BJB0 Frg(v0) / Refrigerator
Frigidaire MDB124BJB1 Universal/dishwasher
Frigidaire MDB125RGR0 Frg(v1)
Frigidaire MDB125RGS0 Frg(v2)
Frigidaire MDB125RHB0 Frg(v1) / Refrigerator
Frigidaire MDB125RHB1 DISHWASHER
Frigidaire MDB125RHB2 Universal/dishwasher
Frigidaire MDB125RHB3 Universal/dishwasher
Frigidaire MDB125RHD0 Tap(v11) / Refrigerator
Frigidaire MDB125RHD1 DISHWASHER
Frigidaire MDB125RHD2 Universal/dishwasher
Frigidaire MDB125RHD3 Universal/dishwasher
Frigidaire MDB125RHS0 Tap(v12) / Refrigerator
Frigidaire MDB125RHS1 DISHWASHER
Frigidaire MDB125RHS2 Universal/dishwasher
Frigidaire MDB125RHS3 Universal/dishwasher
Frigidaire MDB200RBW0 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire MDB202RBD0 Kel(v10) / 24 " Built - in Dishwasher
Frigidaire MDB202RBL0 Frg(v2) / 24 " Built - in Dishwasher
Frigidaire MDB202RBW0 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire MDB212RBS0 Frg(v1) / 24 " Built - in Dishwasher
Maytag MDB2200AWE DISHWASHER- UNDERCOUNTER
Maytag MDB2200AWZ DISHWASHER- UNDERCOUNTER
Frigidaire MDB222RBM0 Frg(v1) / 24 " Built - in Dishwasher
Maytag MDB2400AWE DISHWASHER- UNDERCOUNTER
Maytag MDB2400AWN DISHWASHER- UNDERCOUNTER
Maytag MDB2400AWT DISHWASHER- UNDERCOUNTER
Maytag MDB2400AWZ DISHWASHER- UNDERCOUNTER
Maytag MDB3000AWX DISHWASHER- UNDERCOUNTER
Maytag MDB3100AWE DISHWASHER- UNDERCOUNTER
Maytag MDB3100AWX DISHWASHER- UNDERCOUNTER
Maytag MDB3601AWB0 UNDERCOUNTER DISHWASHER
Maytag MDB3601AWQ0 UNDERCOUNTER DISHWASHER
Maytag MDB3601AWW0 UNDERCOUNTER DISHWASHER
Maytag MDB3601BWB0 UNDERCOUNTER DISHWASHER
Maytag MDB3601BWB1 UNDERCOUNTER DISHWASHER
Maytag MDB3601BWQ0 UNDERCOUNTER DISHWASHER
Maytag MDB3601BWQ1 UNDERCOUNTER DISHWASHER
Maytag MDB3601BWS0 UNDERCOUNTER DISHWASHER
Maytag MDB3601BWS1 UNDERCOUNTER DISHWASHER
Maytag MDB3601BWW0 UNDERCOUNTER DISHWASHER
Maytag MDB3601BWW1 UNDERCOUNTER DISHWASHER
Maytag MDB3700AWE DISHWASHER- UNDERCOUNTER
Maytag MDB3700AWN DISHWASHER- UNDERCOUNTER
Maytag MDB3700AWX DISHWASHER- UNDERCOUNTER
Maytag MDB4000AWA DISHWASHER- UNDERCOUNTER
Maytag MDB4000AWB DISHWASHER- UNDERCOUNTER
Maytag MDB4000AWW DISHWASHER- UNDERCOUNTER
Maytag MDB4000AWX DISHWASHER- UNDERCOUNTER
Maytag MDB4010AWA DISHWASHER- UNDERCOUNTER
Maytag MDB4010AWB DISHWASHER- UNDERCOUNTER
Maytag MDB4010AWW DISHWASHER- UNDERCOUNTER
Maytag MDB4030AWA DISHWASHER- UNDERCOUNTER
Maytag MDB4030AWB DISHWASHER- UNDERCOUNTER
Maytag MDB4030AWW DISHWASHER- UNDERCOUNTER
Maytag MDB4040AWA DISHWASHER- UNDERCOUNTER
Maytag MDB4040AWB DISHWASHER- UNDERCOUNTER
Maytag MDB4040AWW DISHWASHER- UNDERCOUNTER
Maytag MDB4040AWX DISHWASHER- UNDERCOUNTER
Maytag MDB4050AWA DISHWASHER- UNDERCOUNTER
Maytag MDB4050AWB DISHWASHER- UNDERCOUNTER
Maytag MDB4050AWW DISHWASHER- UNDERCOUNTER
Maytag MDB4100AWB DISHWASHER- UNDERCOUNTER
Maytag MDB4100AWQ DISHWASHER- UNDERCOUNTER
Maytag MDB4100AWW DISHWASHER- UNDERCOUNTER
Maytag MDB4100AWX DISHWASHER- UNDERCOUNTER
Maytag MDB4160AWB DISHWASHER- UNDERCOUNTER
Maytag MDB4160AWQ DISHWASHER- UNDERCOUNTER
Maytag MDB4160AWW DISHWASHER- UNDERCOUNTER
Frigidaire MDB421RFR0 Frg(v0) / Built - in Dishwasher
Frigidaire MDB421RFR1 Frg(v1) / Built - in Dishwasher
Frigidaire MDB421RFR2 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire MDB421RFR3 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire MDB421RFS1 Frg(v2) / Built - in Dishwasher
Frigidaire MDB421RFS2 Frg(v2) / 24 " Built - in Dishwasher
Frigidaire MDB421RFS3 Frg(v2) / 24 " Built - in Dishwasher
Frigidaire MDB421RFS4 Frg(v0) / Refrigerator
Frigidaire MDB421RHS0 Frg(v0) / Refrigerator
Frigidaire MDB421RHS1 Frg(v0) / Dishwasher
White Westinghouse MDB421RHS2 White Westinghouse/dishwasher
White Westinghouse MDB421RHS3 White Westinghouse/dishwasher
Frigidaire MDB421RJB0 Universal/dishwasher
Maytag MDB4600AWE DISHWASHER- UNDERCOUNTER
Maytag MDB4600AWX DISHWASHER- UNDERCOUNTER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher Stops After Initial Wash Cycle esmiley Dishwasher Repair 0 06-23-2012 07:10 AM
Maytag Neptune TL Stops in Wash mbacko1 Washer Repair 6 06-03-2012 10:31 AM
maytag neptune stops after wash cycle willy t Washer Repair 1 05-22-2012 05:49 PM
Dishwasher starts...stops...does not wash mrizzo Dishwasher Repair 0 01-01-2012 06:13 PM
Dishwasher stops at wash cycle/overheats Sawspa Dishwasher Repair 1 01-28-2010 03:42 AM
