Discuss
Bocsh overfills and won't drain
 in
Dishwasher Repair
It seems to go through the wash and rinse without draining any water. There is so much water its leaking
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bocsh overfills and won't drain
  #1 (permalink)
Old 09-25-2009, 07:10 AM
shub shub is offline
Junior Member
shub is on a distinguished road
Default Bocsh overfills and won't drain
Brand: Bosch   Age: 1 - 5 years
It seems to go through the wash and rinse without draining any water. There is so much water its leaking out the bottom of the door.
Then Clean light comes on - skipping the sanitizer because its full of water.
I open the door and water all over the floor.
I tried hitting Drain-Cancel but it won't drain.
Has anyone had the same problem - how was it fixed.
The plumbing is fine, the hoses were not moved at anytime. We have had the dishwasher for 2.5 years.
  #2 (permalink)
Old 09-29-2009, 09:29 AM
Junior Member
Default
I did what everyone suggests in the forums, check the drain hose, the drain, check for debris in the bottom that would clog the drain pump. Everything seemed ok.
I Called a local parts store here in Ottawa (regional factory) and they said its the drain pump that needs replacing, its common on bosch.
So I ordered the part and installed it and everything works now. The dishwasher has done serveral loads now with no problems.
Removing and installing the pump is not easy. You have to take off the left panel and reach in around the hoses. Now that I have done one if I had to do it again it would be much easier and quicker.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer overfills jeff 72 Washer Repair 1 08-21-2009 05:29 AM
Icemaker overfills davebloyd Refrigerator & Freezer Repair 2 06-13-2009 08:53 AM
Ice Maker overfills Loree Refrigerator & Freezer Repair 1 05-29-2009 03:22 PM
washer overfills when on dave titan Washer Repair 1 04-28-2009 09:07 PM
GE Icemaker Overfills just a little bit rmcardam Refrigerator & Freezer Repair 6 03-27-2008 10:58 AM
