Appliance Repair Forum
-   Dishwasher Repair (http://forum.appliancepartspros.com/dishwasher-repair/)
-   -   bosch dihwasher (http://forum.appliancepartspros.com/dishwasher-repair/504182-bosch-dihwasher.html)
worrellconstruction llc 10-23-2012 07:33 PM
bosch dihwasher
washer is covered with condensation . the back wall is covered , bottom of the counter is swollen. No water is on the floor . no leak in the drain line. There also is no pressure on the door when closing tight.
Gene 10-24-2012 07:14 PM
What is the complete model number of the dishwasher?
worrellconstruction llc 10-25-2012 07:39 AM
the model number for dishwasher with condensatio all over it is # SHE 44CO5UC/43
Gene 10-25-2012 03:53 PM
Did you replace the detergent disperser recently?
worrellconstruction llc 10-25-2012 05:15 PM
No soap dispensor change. She had the electronic board in the door replaced. Tha the only service on machine.
Gene 10-25-2012 05:43 PM
Pull the dishwasher out of the cabinet. Remove the right side panel and check the condensation tube which is attached to side of the dishwasher and coming down under the tub.
worrellconstruction llc 10-25-2012 06:55 PM
Is that the same as the drain line? Or is this a different line. I will check tomorrow. Thanks for info.
Gene 10-25-2012 07:16 PM
No, it has nothing to do with drain.
