Discuss
Mouse ate Hose Under Dishwasher
 in
Dishwasher Repair
A mouse ate black rubber hose under dishwasher on left front side. I see the diagram 6 tub assy to
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Mouse ate Hose Under Dishwasher
  #1 (permalink)
Old 01-31-2008, 10:21 AM
ddmouse ddmouse is offline
Junior Member
ddmouse is on a distinguished road
Unhappy Mouse ate Hose Under Dishwasher
Model Number: GU94OSCGQ2   Brand: Whirlpool   Age: 5 - 10 years
A mouse ate black rubber hose under dishwasher on left front side. I see the diagram 6 tub assy to this model (GU94OSCGQ2), and think it is fill hose item 37. I see under dishwasher where to clamp this hose - but cannot tell from diagram or by looking underneath, where the other end of the hose is supposed to go? It was demolished by the mouse. It looks easy to replace, but do I need to pull the unit out from cabinet (I hope not). Where does other side connect to? Or, does this sound like the right hose that was eaten or could it be another?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-31-2008, 10:59 AM
bentwrench1999 bentwrench1999 is offline
Senior Expert
APP Volunteer
bentwrench1999 is on a distinguished road
Thumbs up Mouse ate Hose Under Dishwasher
This is common in our area with mice. The part # is AP2904734 inlet hose. One end is from the water valve and the other goes to the side of the tub (siphon break). You will need to pull the d/w forward enough to gain access to the hose and clamp. Usually this not too difficult, depending on if your supply line is flexible or solid. Good Luck...wrench
__________________
  #3 (permalink)
Old 02-09-2008, 07:19 PM
Junior Member
Default
Thanks. Got the part. Got the unit out. Replaced it. Easy! Thanks so much!!!
  #4 (permalink)
Old 02-09-2008, 11:41 PM
Senior Expert
APP Volunteer
I'm Happy you got your dishwasher fixed...
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Drain Hose on Bosch Dishwasher Lorenzo Dishwasher Repair 3 10-02-2008 12:31 PM
Drain Hose Connection To Tub YAHOO21 Washer Repair 2 11-20-2007 06:56 PM
Not draining...hose clear mjpalad Dishwasher Repair 4 10-22-2007 10:57 AM
Water dispenser hose replacement. trcpal Refrigerator & Freezer Repair 0 08-29-2007 08:40 PM
Injector hose leaks when water pressure is low edpinarello Washer Repair 0 08-11-2007 12:13 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
