| » Maytag dishwasher problems |
Model Number: MDB7130AWS Brand: Maytag Age: 5 - 10 years
My dishwasher will fill but the wash and drain cycles won't turn on -- just clicking noise. I removed control board and found 2 resistors were hot to touch and the board was discolored where they are located (R301 & R302)
It looks like they could be the problem. Do I need to replace the whole board or can I just replace the resistors. Where can I find a new control board if it needs to be replaced? There is a number on the board 60D20960401. Thank you for your service. Ads By Google Related Models |
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG MDB7130AWS | AppliancePartsPros.com I would check the following first http://www.servicematters.com/maytag...DD-0011B-B.pdf It looks like they could be the problem. Do I need to replace the whole board or can I just replace the resistors. You would have to replace the board. The resistors are probably OK since they are heating up somewhat, we know current is going through them. I cannot get schematics of the boards so cannot troubleshoot down to component level on them. I would remove the plug from the motor and check it with a meter to ensure the windings are OK. Also check that it is not jammed up. Where can I find a new control board if it needs to be replaced? See the parts link.
__________________
| Display Modes | |
| Control Panel Problems for Maytag Dishwasher | tommyboy84 | Dishwasher Repair | 7 | 05-17-2013 06:56 AM |
| Maytag Mav6457aww Problems | DODGEGIRL | Washer Repair | 1 | 02-17-2010 06:21 PM |
| Maytag Dishwasher heater problems | tkrueger | Dishwasher Repair | 0 | 01-09-2010 08:40 AM |
| Maytag Oven problems | kevinw3 | Oven Repair (including Ranges and Cooktops) | 1 | 06-15-2009 02:34 PM |
| MAYTAG dishwasher timer problems | mrookian | Dishwasher Repair | 0 | 07-23-2008 05:13 PM |
