| » Whirlpool washer agitate cycle |
Model Number: A680OXSN1 Brand: Whirlpool Age: More than 10 years
I have a Whirlpool washer, model #A680OXSN1. It is an older model. I mostly use the delicate cycle. The water fills ok but then when it starts to agitate it doesn't agitate for the full time. Then sometimes when the water starts to drain water will start to fill at the same time. Sometimes it won't agitate at all, it just doesn't do anything. It is starting to act like this on the regular cycle now to. What is wrong? Can I fix it myself? Thanks
I couldn't get anything to come up with that number. Could you recheck it and read it off the tag on the machine
Try different cycles and see if the same problem exists in all the cycles or just a couple.
__________________
Ricks Appliance Repair |
Thanks for you response. Yes, that is the correct model#. I can read it clearly. It is a Whirlpool Super Capicity Imperial. I just ran the regular cycle and the agitation worked ok except at the begining of the 2nd spin cycle it spit out water for about 5 seconds, but it finished the cycle ok. Now, I have had the same problem with the regular cycle where it doesn't agitate, or only agitates for a short time, but not as much as I do with the delicate cycle. On the delicate cycle the agitation pretty much doesn't work correctly anytime. It either works only for a short time or doesn't work at all.
I don't know how to tell if it is Canadian. I don't live in Canada. I guess I would have to take it apart to tell if it is a belt drive or not and I haven't done that. If you think it is a timer issue, how do I replace that. Is it fairly easy?
That number you listed looks like a serial number, not a model number. Lift the washer lid and look for the tag towards the back of the opening. Whirlpool model numbers usually start with three letters and then four numbers like LAW5650-example only
__________________
Serial # is C84926889 Stock #LA68005
That model # is on the same metal tag.
| Display Modes | |
| Washer won't advance through agitate cycle | ashton64 | Washer Repair | 3 | 05-20-2011 09:49 AM |
| Whirlpool won't stop filling and never kicks over to the agitate cycle | btsq48 | Washer Repair | 3 | 01-24-2010 01:20 PM |
| Whirlpool won't fill w/ Water, skips to agitate/wash cycle. | jeshurun41 | Washer Repair | 3 | 12-27-2009 04:29 AM |
| Washer won't agitate during rinse cycle | bd2con | Washer Repair | 4 | 09-11-2009 07:18 PM |
| Washer does not agitate but it spins at end of cycle. | Robert D | Washer Repair | 0 | 10-22-2008 09:30 AM |
