rinse dispenser malfunction?
Recently unit has apparently been dispensing too much rinse aid. Near end of cycle unit sounds as if it is barely moving any water and when door is opened a large amount of bubbles are in rinse water. There is an adjustment inside the rinse dispenser cap and it it turned to the lowest position possible. Have not changed detergent or rinse aid brands. This problem does not exist until the end of cycle but is present regardless of the cycle selected rather than the rinse only cycle of course.
The solution is to replace the soap and rinse aid dispenser.
- The dispenser Part number: 99003317 Here are the breakdown diagrams and Parts for Maytag MDC4650AWW Dishwasher - AppliancePartsPros.com Gene. |
Thanks Gene!
Gene. |
| All times are GMT -7. The time now is 10:59 AM. |
