Discuss
Leak From Heater Assembly
 in
Dishwasher Repair
Had years of trouble free operation. Replaced door seal and leaky drain hose due to pin hole. Recently dishwasher stopped
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Leak From Heater Assembly
  #1 (permalink)
Old 10-15-2012, 06:09 AM
Junior Member
mrago is on a distinguished road
Default Leak From Heater Assembly
Model Number: SHU9915uc/u06   Brand: Bosch   Age: More than 10 years
Had years of trouble free operation. Replaced door seal and leaky drain hose due to pin hole. Recently dishwasher stopped working. Noticed water in the bottom tray. Removed unit and set up on work bench . Removed front cover and left panel to expose switches etc. Checked water inlet valve.. ok with ohmmeter and powered on off. Checked float switch and level switch ok. Ran diagnostic program and watched for leaks with flashlight. Noticed some dripping from heater unit assembly. Question: Does the whole unit have to be replaced or are there seals/gaskets that might be causing the leak. Heat works.
Hope someone can give me some advice before I just go and buy a whole new heater assembly. We replaced this with an LG unit but I dont want to give this great dishwasher up.. can use it as a second unit in our basement rec room area. thanks to anyone who can help
Ads By Google
Related Models
Bosch SHU9916 UC/06
Bosch SHU9916 UC/06 (FD 7908-8002)
Bosch SHU9916 UC/11
Bosch SHU9916 UC/11 (FD 8002-8003)
Bosch SHU9916 UC/12
Bosch SHU9916 UC/12 (FD 8003-)
Bosch SHU9922 UC/12 (FD 8003-)
Bosch SHU9925 UC/12 (FD 8003-)
Bosch SHU9926 UC/12 (FD 8003-)
Bosch SHU9952 UC/12 (FD 8105 -)
Bosch SHU9955 UC/12 (FD 8105 -)
Bosch SHU9956 UC/12 (FD 8105 -)
Bosch SHV4303 UC/06
Bosch SHV4303 UC/06 (FD 7712-8002)
Bosch SHV4303 UC/11
Bosch SHV4303 UC/11 (FD 8002-8003)
Bosch SHV4303 UC/12
Bosch SHV4303 UC/12 (FD 8003-)
Bosch SHV46C03 UC/14 (FD 8211-)
Bosch SHV4803 UC/06
Bosch SHV4803 UC/06 (FD 7712-7812, 7905-7907)
Bosch SHV4803 UC/07
Bosch SHV4803 UC/07 (FD 7812-7905, 7907-8010)
Bosch SHV4803 UC/12
Bosch SHV4803 UC/12 (FD 8010-)
Bosch SHV66A03 UC/14 (FD 8301-)
Bosch SHV6803 UC/12 (FD 8105 -)
Bosch SHV99A03 UC/14 (FD 8212-)
Hoover SHWA2501A Washer - Top Loading
Hoover SHWA2501W Washer - Top Loading
Hoover SHWA2506A Washer - Top Loading
Hoover SHWA2506AT Washer - Top Loading
Hoover SHWA2506W Washer - Top Loading
Hoover SHWA2506WT Washer - Top Loading
Hoover SHWA2507A Washer - Top Loading
Hoover SHWA2507V Washer - Top Loading
Hoover SHWA2507W Washer - Top Loading
Bosch SHX33A02 UC/14 (FD 8211-)
Bosch SHX33A05 UC/14 (FD 8211-)
Bosch SHX33A06 UC/14 (FD 8211-)
Bosch SHX43E02 UC/14 (FD 8211-)
Bosch SHX43E05 UC/14 (FD 8211-)
Bosch SHX43E06 UC/14 (FD 8211-)
Bosch SHX46A02 UC/14 (FD 8211-)
Bosch SHX46A05 UC/14 (FD 8211-)
Bosch SHX46A06 UC/14 (FD 8211-)
Bosch SHX46A07 UC/14 (FD 8211-)
Bosch SHX46B02 UC/14 (FD 8211-)
Bosch SHX46B05 UC/14 (FD 8211-)
Bosch SHX46B06 UC/14 (FD 8211-)
Bosch SHX46B07 UC/14 (FD 8211-)
Bosch SHX56B02 UC/14 (FD 8211-)
Bosch SHX56B05 UC/14 (FD 8211-)
Bosch SHX56B06 UC/14 (FD 8211-)
Bosch SHX99B05 UC/14 (FD 8212-)
Bosch SHX99B06 UC/14 (FD 8212-)
Bosch SHY56A02 UC/14 (FD8301-)
Bosch SHY56A05 UC/14 (FD8301-)
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
Bosch SHY99A06 UC/14 (FD 8212-)
Amana SI19E Ref - SXS/I&W
General Electric SIG7010ET1WG Electric dryer
International SILVER22 Ref - SXS/I&W
International SILVER24 Ref - SXS/I&W
Maytag SK525-2W  Ref - Sxs
Maytag SK535-2  Ref - SXS/I&W
Gaggenau SK590-2  Ref - Bottom Mounts
Hardwick SKG4622MGA639R Range - F/s Cont Clean Gas
Hardwick SKG4622MGW639R Range - F/s Cont Clean Gas
Hardwick SKG9611A540R Range - F/s Cont Clean Gas
Hardwick SKG9611W540R Range - F/s Cont Clean Gas
Amana SKI22F Ref - SXS/I&W
Amana SKI22F-A Ref - SXS/I&W
Amana SKI22F-C Ref - SXS/I&W
Amana SKI22F-G Ref - SXS/I&W
Amana SKI22FL Ref - SXS/I&W
Hardwick SKJ7141819DE Walloven - Cont Clean Gas
Maytag SL10AA Stacked Laundry - Ele
Maytag SL10AA-A01 Stacked Laundry - Ele
Maytag SL10AN Stacked Laundry - Ele
Maytag SL10AN-A00 Stacked Laundry - Ele
Maytag SL10AN-A01 Stacked Laundry - Ele
Maytag SL10AN-A02 Stacked Laundry - Ele
Maytag SL10AN-A03 Stacked Laundry - Ele
Maytag SL11AA Stacked Laundry - Ele
Maytag SL11AN Stacked Laundry - Ele
General Electric SL208 Room air conditioner
General Electric SL210 Room air conditioner
General Electric SL212 Room air conditioner
General Electric SL214 Room air conditioner
General Electric SL217 Room air conditioner
General Electric SL220 Room air conditioner
General Electric SL223 Room air conditioner
Amana SL22F Ref - SXS/I&W
Amana SL22F-A Ref - SXS/I&W
Amana SL22F-C Ref - SXS/I&W
Amana SL22F-G Ref - SXS/I&W
Amana SL22F-L Ref - SXS/I&W
Amana SL22G Ref - SXS/I&W
Amana SL22GL Ref - SXS/I&W
Amana SL22JB Ref - SXS/I&W
Amana SL22MBG Ref - SXS/I&W
Amana SL22MBL Ref - SXS/I&W
Amana SL22MBW Ref - SXS/I&W
Amana SL25G Ref - SXS/I&W
Amana SL25GL Ref - SXS/I&W
Amana SL25H Ref - SXS/I&W
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Assembly heater duct gvzh39 Dryer Repair 3 08-16-2010 06:30 AM
New heater assembly? repair61 Dishwasher Repair 0 04-18-2010 08:07 AM
frigidaire heater assembly ampjjs Dryer Repair 1 12-26-2008 01:07 PM
Heater sub-assembly dupontjams Dryer Repair 1 02-28-2008 01:18 PM
Heater sub-assembly dupontjams Dryer Repair 1 02-28-2008 01:16 PM
