| » Amana stops mid cycle, drains & shuts off |
Model Number: ADB1400AWQ1 Brand: Amana Age: 1 - 5 years
After about 15-30 minutes my Amana dishwasher will stop mid-cycle, drain, and then shut off (including all of the indicator lights on the panel). I can always get it to re-start but it will usually shut off again after running for a while. On rare occasions it will finish the cycle. We purchased it new 14 months ago. After it stops I have tried opening and re-closing the door to make sure it is sealed but it doesn't seem to help. Any ideas?
Quote:
I have the same model and the same problem. Did you find a solution? Has anyone seen this problem? Do I need to replace the control board? Thanks |
JG
Thanks - I was getting ready to order and install a new control board. I think I'll just wait it out. Is there anything you did besides continued use to "resolve" the problem (e.g., run a cleaning cycle with a decalcifier). My guess is that the software control program is incorrectly sensing that something bad is happening the the machine should drain and cancel, but I have no ideas whether this is possible. I don't think it is the membrane switch. I'll post again if: 1)the problem goes away; 2) I get an answer from Amana( I am thinking of calling Mr. Jeff Fettig); 3) I replace the control board; or 4) If I figure out what is going on. I could hook a logic analyzer to the control board, but that would be overkill and a pain. I posted the problem on another forum and so far no solutions offered. Mr. Smith please post if you find a solution, and I'll do the same. Thanks Barry |
I didn't do anything else to resolve the problem, but ever since it started running well through the whole cycle I always make sure that the racks are pushed all the way in and that the door is closed snugly and it has continued to run well ever since. My husband originally felt that it might have something to do with the door latch not being tight enough. I wish I could tell you exactly what caused it to start working well again. Good luck!
Thanks.
I have run a few 1 hour cycles using a decalcifier and the dishwasher ran OK. I'll check the racks. I don't think it is the door latch because when I open the door while it is running, nothing initiates a drain/cancel cycle. When I saw it fail once, the red LED indicating drain/cancel turn on as if the button was pressed. |
So after a couple of cleaning cycles (using Lemi Shine) the ADB 1400 runs normal wash cycles to completion.
So I'm guessing that: 1) Some sensor was causing the premature cancel/drain cycle; 2) The controller was programmed to generate a service call after the warranty period had expired (when I called Amana they said to replace the controller board for $150); or 3) The controller board is very flaky. I remember this dishwasher had some strange initial startup problem which was resolved by removing power from the dishwasher. Hopefully the problem will not return (as described above by jgilber "The problem resolved on its own and has never returned. No repair needed.") |
| Display Modes | |
| only spin cycle and drains. no agitate, water fill or rinse cycle | reyd1 | Washer Repair | 0 | 07-01-2012 07:40 AM |
| Amana washer stops and hums mid-cycle | powersct | Washer Repair | 0 | 08-12-2011 04:42 PM |
| Retaining water after a normal cycle, drains fine on drain cycle | HandyHubby | Dishwasher Repair | 0 | 10-14-2010 04:02 PM |
| Washer stops in middle of cycle shuts off | hellmanjeffrey@yahoo.com | Refrigerator & Freezer Repair | 4 | 01-10-2010 09:19 AM |
| Washer drains and balances load no spin shuts off | Ken Dankenbring | Washer Repair | 5 | 09-29-2009 02:01 PM |
