| » Ldf6920 Check valve motor |
Model Number: Ldf6920st Brand: -other- Age: 1 - 5 years
My lower arm won't spin and I've taken the sump assembly apart. Looks like the check valve is not spinning from upper to lower spray arms? I rotated it by hand to the lower arms and it now works the lower only. Even when I start washer on upper only setting. I figure it's the motor since everything is clean and rotates fine. I found part #4681ed3001d as the motor. What else should I change out with it since I will have to remove the dishwasher? Any help would be great.
Hi.
Check the continuity of the motor winding, check if it' getting the 120VBAC from the control board. If there is voltage - replace the motor. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
You are welcome.
Post the results. Simon.
__________________
| Display Modes | |
| Check Valve | Link05 | Dishwasher Repair | 1 | 01-01-2011 07:38 AM |
| What is the function os a CHECK VALVE? | jerryandtabatha | Dishwasher Repair | 2 | 08-24-2010 09:47 AM |
| Check valve replacement | marc74 | Dishwasher Repair | 1 | 11-18-2009 02:10 PM |
| Need Check Valve for Part 560 Body Valve | mjt | Dishwasher Repair | 0 | 08-31-2009 07:08 AM |
| check valve | needtoknow | Dishwasher Repair | 0 | 08-26-2009 05:05 PM |
