Discuss
Drain Pump will not turn off
 in
Dishwasher Repair
LG Dishwasher Model LDF6810BB I'm having an issue where my dishwasher drain pump is continuously running. There is no water
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Drain Pump will not turn off
  #1 (permalink)
Old 10-05-2012, 07:11 AM
Junior Member
jhamm is on a distinguished road
Default Drain Pump will not turn off
Model Number: LDF6810BB   Brand: -other-   Age: 1 - 5 years
I'm having an issue where my dishwasher drain pump is continuously running. There is no water in the dishwasher so I believe it is draining but I woke up this morning to see that the dishwasher was still "running". It won't stop until I turn off the breaker but when I turn the breaker back on it starts the drain pump again. What could be causing this?
Ads By Google
Related Models
International LDG1000AAE Dryer - Gas
Maytag LDG105 Dryer - Gas
Maytag LDG107 Dryer - Gas
Maytag LDG110 Dryer - Gas
Maytag LDG18CA Dryer - Gas
Maytag LDG18CM Dryer - Gas
Maytag LDG18CS Dryer - Gas
Maytag LDG18CT Dryer - Gas
Maytag LDG19CD Dryer - Gas
Maytag LDG19CS Dryer - Gas
Maytag LDG19CT Dryer - Gas
Maytag LDG210 Dryer - Gas
Maytag LDG212 Dryer - Gas
Maytag LDG21CS Dryer - Gas
Maytag LDG22CS Dryer - Gas
Maytag LDG22CT Dryer - Gas
Maytag LDG23CD Dryer - Gas
Maytag LDG24CA Dryer - Gas
Maytag LDG24CM Dryer - Gas
Maytag LDG24CS Dryer - Gas
Maytag LDG24CT Dryer - Gas
Maytag LDG25CS Dryer - Gas
Maytag LDG26CA Dryer - Gas
Maytag LDG26CD Dryer - Gas
Maytag LDG26CS Dryer - Gas
Maytag LDG26CT Dryer - Gas
Maytag LDG27CA Dryer - Gas
Maytag LDG27CD Dryer - Gas
Maytag LDG27CS Dryer - Gas
Maytag LDG27CT Dryer - Gas
Maytag LDG303 Dryer - Gas
Maytag LDG303D Dryer - Gas
Maytag LDG306 Dryer - Gas
Maytag LDG308 Dryer - Gas
Maytag LDG309 Dryer - Gas
Maytag LDG30CMD Dryer - Gas
Maytag LDG312 Dryer - Gas
Maytag LDG312D Dryer - Gas
Maytag LDG313 Dryer - Gas
Maytag LDG313D Dryer - Gas
Maytag LDG31CA Dryer - Gas
Maytag LDG31CM Dryer - Gas
Maytag LDG31CT Dryer - Gas
Maytag LDG32CA Dryer - Gas
Maytag LDG32CM Dryer - Gas
Maytag LDG32CT Dryer - Gas
Frigidaire LDG333PEW0 Frg(v0) / Gas Dryer
Maytag LDG33CA Dryer - Gas
Maytag LDG33CM Dryer - Gas
Maytag LDG34CD Dryer - Gas
Maytag LDG34CQ Dryer - Gas
Maytag LDG382 Dryer - Gas
Maytag LDG4000 Dryer - Gas
Maytag LDG4000AAL Dryer - Gas
Maytag LDG4000AAW Dryer - Gas
Maytag LDG4000ABL Dryer - Gas
Maytag LDG4000ABW Dryer - Gas
Maytag LDG407 Dryer - Gas
Maytag LDG408 Dryer - Gas
Maytag LDG409 Dryer - Gas
Maytag LDG410 Dryer - Gas
Maytag LDG412 Dryer - Gas
Maytag LDG412D Dryer - Gas
Maytag LDG482 Dryer - Gas
Maytag LDG482D Dryer - Gas
Maytag LDG490 Dryer - Gas
Maytag LDG490D Dryer - Gas
Maytag LDG4910 Dryer - Gas
Maytag LDG4910AAL Dryer - Gas
Maytag LDG4910AAW Dryer - Gas
Maytag LDG4914AAE Dryer - Gas
Maytag LDG4914AAL Dryer - Gas
Maytag LDG4914AAM Dryer - Gas
Maytag LDG4916AAE Dryer - Gas
Maytag LDG4916AAM Dryer - Gas
Maytag LDG5004AAW Dryer - Gas
Maytag LDG5004ABW Dryer - Gas
Maytag LDG5005AAE Dryer - Gas
Maytag LDG5005ABE Dryer - Gas
Maytag LDG510 Dryer - Gas
Maytag LDG512 Dryer - Gas
Maytag LDG512D Dryer - Gas
Maytag LDG590 Dryer - Gas
Maytag LDG590D Dryer - Gas
Maytag LDG5910 Dryer - Gas
Maytag LDG5910AAL Dryer - Gas
Maytag LDG5910AAW Dryer - Gas
Maytag LDG5914AAE Dryer - Gas
Maytag LDG5914AAL Dryer - Gas
Maytag LDG5914AAM Dryer - Gas
Maytag LDG5916AAE Dryer - Gas
Maytag LDG5916AAM Dryer - Gas
Maytag LDG6004AAW Dryer - Gas
Maytag LDG606 Dryer - Gas
Maytag LDG608 Dryer - Gas
Maytag LDG610 Dryer - Gas
Maytag LDG612 Dryer - Gas
Maytag LDG612D Dryer - Gas
Maytag LDG6914AAE Dryer - Gas
Maytag LDG6914AAL Dryer - Gas
Maytag LDG6914AAM Dryer - Gas
Maytag LDG710 Dryer - Gas
Maytag LDG712 Dryer - Gas
Maytag LDG713 Dryer - Gas
Maytag LDG7304AAE Dryer - Gas
Maytag LDG7304AAL Dryer - Gas
Maytag LDG7304AAM Dryer - Gas
Maytag LDG7304ABE Dryer - Gas
Maytag LDG7304ABL Dryer - Gas
Maytag LDG7304ABM Dryer - Gas
Maytag LDG7304AGE Dryer - Gas
Maytag LDG7304AGL Dryer - Gas
Maytag LDG7304AGM Dryer - Gas
Maytag LDG7304EGE Dryer - Gas
Maytag LDG7304EGL Dryer - Gas
Maytag LDG7304EGM Dryer - Gas
Maytag LDG7314AAE Dryer - Gas
Maytag LDG7314AAL Dryer - Gas
Maytag LDG7314AAM Dryer - Gas
Maytag LDG7334AAE Dryer - Gas
  #2 (permalink)
Old 10-05-2012, 11:17 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Constantly running drain pump indicates that there is water on the bottom under the cavity.
Dry it (use sponge, paper towel) and use it trying to find the leak.It may not happen again.
Here are the breakdown diagrams and Replacement parts for LG LDF6810BB Dishwasher | AppliancePartsPros.com
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 10-05-2012, 11:20 AM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Simon.
Thanks, I'm not very technical. Where should I be looking as far as the "cavity"? Do I have to turn the machine over?
  #4 (permalink)
Old 10-05-2012, 11:37 AM
Expert
Default
When you open the door and look inside - what you see is called "cavity".
The drain pump is under it. You can get to it from the sides or back to dry the water.
Unplug the unit before working.
Simon.
__________________
  #5 (permalink)
Old 10-05-2012, 12:10 PM
Junior Member
Default
Simon.
Simon, I appreciate your help with this. I thought the inside was referred to as the tub. There doesn't appear to be any water inside at all (like around the spray arm). Perhaps I'm looking in the wrong place. Should I be looking on the inside of the door?
  #6 (permalink)
Old 10-05-2012, 12:56 PM
Expert
Default
If you pull the dishwasher out and look from the side or the back you'll understand what I'm talking about.
Did you open the diagrams?
Simon.
__________________
  #7 (permalink)
Old 10-05-2012, 03:13 PM
Junior Member
Default
Simon, I took the dishwasher out, looked in the sides and the back and saw no water. I also tipped it on its side and water seemed to come out of the door area onto the floor. I let water come out and turned it back on and the issue persists where the drain pump keeps on.
  #8 (permalink)
Old 10-05-2012, 03:21 PM
Junior Member
Default
Update:
I tipped it on it's side again with the door slightly open and saw the water is actually coming out of the sump area in the middle of the tub and then coming out the side of the door. Could there be blockage?
  #9 (permalink)
Old 10-05-2012, 04:23 PM
Junior Member
Default
I took off the spray arm and looked down inside. there seemed to be a little bit of water near the heating element (I presume it's the heating element).
  #10 (permalink)
Old 10-05-2012, 05:34 PM
Expert
Default
Hi.
Sorry for the delay. Based on the info we have the recommendation is to replace the float switch asm. Part#M090 on the diagram#2.( 4769DD2001A )
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
drain pump wont turn off willhess Dishwasher Repair 0 03-21-2011 04:33 AM
Dishwasher pump wont turn off. james pollack Dishwasher Repair 2 11-27-2010 07:27 AM
dishwasher will not drain (drain pump is new) jkda1975 Dishwasher Repair 1 04-06-2010 01:56 PM
bosch shu9925 - drain pump works, won't drain after cycle mjbarr Dishwasher Repair 0 10-16-2009 01:11 PM
will this pump also pump the drain water out Paul Radovsky Dishwasher Repair 5 07-20-2008 01:41 PM
