Discuss
Washer fills, waits, drains,repeats
 in
Dishwasher Repair
OK, I know a few things but not enough about dishwashers so I would appreciate any help. My dishwasher, will
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Washer fills, waits, drains,repeats
  #1 (permalink)
Old 10-03-2012, 09:10 AM
Junior Member
WEASEL36 is on a distinguished road
Default Washer fills, waits, drains,repeats
Model Number: 58715102800   Brand: Kenmore   Age: 1 - 5 years
OK, I know a few things but not enough about dishwashers so I would appreciate any help. My dishwasher, will start, fill the tub,(the float and switch both work) and then sit there for 5 minutes or so. I took the connector off the circulation motor and got around 10 volts and then when I heard the click that it was done filling it dropped to 6. Then stayed there and never moved, then after the 5 minutes the drain motor kicked in and drained it. (drain motor get 120volts and works fine when called upon). It will repeat this sequence. Is the control panel not sending the voltage to the agitator? Or does it have something to do with the water temp?
Ads By Google
Related Models
Kenmore 58715102800 DISHWASHER
Kenmore 58715102801 DISHWASHER
Kenmore 58715103800 DISHWASHER
Kenmore 58715103801 DISHWASHER
Kenmore 58715104800 DISHWASHER
Kenmore 58715104801 DISHWASHER
Kenmore 5871510590 DISHWASHER
Kenmore 58715109800 DISHWASHER
Kenmore 58715109801 DISHWASHER
Kenmore 5871511590 BUILT-IN DISHWASHER
Kenmore 58715132400 DISHWASHER
Kenmore 58715132401 DISHWASHER
Kenmore 58715132402 DISHWASHER
Kenmore 58715132403 DISHWASHER
Kenmore 58715139400 DISHWASHER
Kenmore 58715139401 DISHWASHER
Kenmore 58715139402 DISHWASHER
Kenmore 58715139403 DISHWASHER
Kenmore 58715142400 DISHWASHER
Kenmore 58715142401 DISHWASHER
Kenmore 58715142402 DISHWASHER
Kenmore 58715142403 DISHWASHER
Kenmore 58715142404 DISHWASHER
Kenmore 58715142405 DISHWASHER
Kenmore 58715149400 DISHWASHER
Kenmore 58715149401 DISHWASHER
Kenmore 58715149402 DISHWASHER
Kenmore 58715149403 DISHWASHER
Kenmore 58715149404 DISHWASHER
Kenmore 58715149405 DISHWASHER
Kenmore 58715152400 DISHWASHER
Kenmore 58715152401 DISHWASHER
Kenmore 58715157400 DISHWASHER
Kenmore 58715158400 DISHWASHER
Kenmore 58715158401 DISHWASHER
Kenmore 58715159400 DISHWASHER
Kenmore 58715159401 DISHWASHER
Kenmore 58715162400 DISHWASHER
Kenmore 58715162401 DISHWASHER
Kenmore 58715163400 DISHWASHER
Kenmore 58715163401 DISHWASHER
Kenmore 58715163402 DISHWASHER
Kenmore 58715164400 DISHWASHER
Kenmore 58715164401 DISHWASHER
Kenmore 5871516580 KENMORE AUTOMATIC UNDERCOUNTER DISHWAHERS
Kenmore 58715169400 DISHWASHER
Kenmore 58715169401 DISHWASHER
Kenmore 58715173400 DISHWASHER
Kenmore 5871517581 KENMORE AUTOMATIC BUILT-IN DISHWASHER
Kenmore 5871517583 AUTOMATIC BUILT-IN DISHWASHER
Kenmore 5871517585 AUTOMATIC BUILT-IN DISHWASHER
Kenmore 5871517586 DISHWASHER
Kenmore 587151800 KENMORE AUTOMATIC UNDERCOUNTER DISHWASHERS
Kenmore 58715182400 DISHWASHER
Kenmore 58715182401 DISHWASHER
Kenmore 58715182402 DISHWASHER
Kenmore 58715182403 DISHWASHER
Kenmore 58715182404 DISHWASHER
Kenmore 58715188400 DISHWASHER
Kenmore 58715188401 DISHWASHER
Kenmore 58715188402 DISHWASHER
Kenmore 58715188403 DISHWASHER
Kenmore 58715188404 DISHWASHER
Kenmore 58715189400 DISHWASHER
Kenmore 58715189401 DISHWASHER
Kenmore 58715189402 DISHWASHER
Kenmore 58715189403 DISHWASHER
Kenmore 58715189404 DISHWASHER
Kenmore 58715192400 DISHWASHER
Kenmore 58715192401 DISHWASHER
Kenmore 58715192402 DISHWASHER
Kenmore 58715193400 DISHWASHER
Kenmore 58715193401 DISHWASHER
Kenmore 58715193402 DISHWASHER
Kenmore 58715194400 DISHWASHER
Kenmore 58715194401 DISHWASHER
Kenmore 58715194402 DISHWASHER
Kenmore 58715199400 DISHWASHER
Kenmore 58715199401 DISHWASHER
Kenmore 58715199402 DISHWASHER
Kenmore 58715202800 DISHWASHER
Kenmore 58715202801 DISHWASHER
Kenmore 58715202802 DISHWASHER
Kenmore 58715202803A DISHWASHER
Kenmore 58715203800 DISHWASHER
Kenmore 58715203801 DISHWASHER
Kenmore 58715203802 DISHWASHER
Kenmore 58715203803A DISHWASHER
Kenmore 58715212900 DISHWASHER
Kenmore 58715213900 DISHWASHER
Kenmore 58715214900 DISHWASHER
Kenmore 58715219900 DISHWASHER
Kenmore 58715232900 DISHWASHER
Kenmore 58715232900A DISHWASHER
Kenmore 58715233900 DISHWASHER
Kenmore 58715233900A DISHWASHER
Kenmore 58715234900 DISHWASHER
Kenmore 58715234900A DISHWASHER
Kenmore 58715238900 DISHWASHER
Kenmore 58715238900A DISHWASHER
Kenmore 58715239900 DISHWASHER
Kenmore 58715239900A DISHWASHER
Kenmore 58715242700 DISHWASHER
Kenmore 58715242701 DISHWASHER
Kenmore 58715242702 DISHWASHER
Kenmore 58715248700 DISHWASHER
Kenmore 58715248701 DISHWASHER
Kenmore 58715248702 DISHWASHER
Kenmore 58715249700 DISHWASHER
Kenmore 58715249701 DISHWASHER
Kenmore 58715249702 DISHWASHER
Kenmore 58715252400 DISHWASHER
Kenmore 58715252401 DISHWASHER
Kenmore 58715252402 DISHWASHER
Kenmore 58715253400 DISHWASHER
Kenmore 58715253401 DISHWASHER
Kenmore 58715253402 DISHWASHER
Kenmore 58715254400 DISHWASHER
Kenmore 58715254401 DISHWASHER
Kenmore 58715254402 DISHWASHER
  #2 (permalink)
Old 10-03-2012, 01:28 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Based on the info you provided there is a bad control board or broken wire.
Control board Part number: 154776601
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 10-04-2012, 08:29 AM
Junior Member
Default
You were right, it was the control board, but I didn't have to replace it,yet...
Took the panel off, removed the connections, they were a little oxidized, reattched the connections and put it all back together.
Started the cycle hooked up the meter and suddenly, there was a click and the meter read 120 volts!! Plugged in the lead and bam-o, dishwasher works!! Bad connection, at least now I know what or where! Thanks!!!!
  #4 (permalink)
Old 10-04-2012, 12:03 PM
Expert
Default
I am glad you fixed the problem. Thank for shearing with us.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer fills and drains but won't spin? t_reed52 Washer Repair 0 04-04-2012 08:12 PM
washer only fills and drains, eastsrbr Washer Repair 1 01-21-2012 04:41 PM
Washer fills and drains thats it!!! felice Washer Repair 1 10-27-2011 07:08 PM
fills waits then empty out? BruceAttfield Dishwasher Repair 0 09-04-2011 01:36 PM
Whirlpool Washer drains as it fills richard guimbarda Washer Repair 0 07-17-2010 09:58 AM
