| » Removing Door Switch Maytag Dishwasher |
Model Number: MDB6701AWB Brand: Maytag Age: 1 - 5 years
Situation: Dishwasher is dead. I believe a recent power surge damaged some electrical component. I was advised by tech support chat yesterday that either the door switch(es) or control board are most likely the affected components. A friend of mine is bringing over a multimeter tomorrow (Thursday 10/4) so we can test the switches. If they test good, then I assume it's the control board gone bad. (Unless one of you thinks it's the control PANEL instead).
Question/problem: Last night I turned the power off to the machine (at the circuit breaker), removed the door liner/panel and located the door switches. I removed one switch from the door latch assembly. For the life of me, I can't unplug it from the socket at the ends of the wires leading to it. It's in really tight. Is it safe to grip both the switch and socket with tools and yank as hard as I can? Is that the way to unplug them? Also, I see this in the instructions about removing the switches: "Disconnect wires from the Vent and Dispenser Wax Motors before pulling the Inner Door Panel away from the Dishwasher." I'm not sure what that's referring to. Any help? Thanks. Ads By Google Related Models |
Hi.
Don't yank those wires. You may have to push little locking tabs before pulling the contacts off. Don't worry about the wax motors as long as you are not taking out the inner door (Don't have to). Before checking the switch open the toe panel and open small junction box on the right.See if wires are properly connected there. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Thanks for the guidance, Simon. I was just looking at the switch and socket again, this time with reading glasses on, and I could see that there's some type of locking mechanism. I'll need to make doubly sure I've got the power cut off before I use a screwdriver to pry the contact/prong from the socket.
I'll also check the connection as you suggest, but I don't see any reason why that should have changed. The dishwasher was working fine one day, then dead the next. If the switches test OK, can you offer an opinion as to whether the failed component is more likely to be the control board/circuit board or the overal control panel/touch panel? Can these also be tested with a multimeter? Thanks. -Ken |
Hi.
Most likely it's the control board. Check if there is 120VAC at the black and white wires comes from the door switches to the board. If it is - replace the board Part number: W10218837 Good luck. Simon.
__________________
| Display Modes | |
| Maytag Microwave - faulty door switch | glenwards64@yahoo.com | Microwave Repair | 0 | 08-18-2012 12:32 PM |
| maytag mah 8700 aww door switch assembly | xabier67 | Washer Repair | 1 | 03-26-2012 03:23 PM |
| Removing Door Seal to get to Door Switch | married52299 | Washer Repair | 0 | 02-20-2012 11:03 PM |
| Removing In The Door Water Dispensor Micro-Switch | DavidDouglass | Refrigerator & Freezer Repair | 1 | 04-06-2009 12:54 PM |
