Discuss
Kitchenaid Dishwasher - Does not stop taking in water
 in
Dishwasher Repair
Hello - Last night I heard water pouring on the floor my KitchenAid dishwasher, from below the front door. I
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kitchenaid Dishwasher - Does not stop taking in water
  #1 (permalink)
Old 10-02-2012, 08:54 AM
Junior Member
volant is on a distinguished road
Default Kitchenaid Dishwasher - Does not stop taking in water
Model Number: kuds03ctbl3   Brand: Kitchen Aid   Age: 1 - 5 years
Hello -
Last night I heard water pouring on the floor my KitchenAid dishwasher, from below the front door. I examined it and found out that the
intake water valve does not shut off even if I cancel the program or cut of power. I shut off the water valve in front of the machine
and press Cancel to drain the water. Then I open the valve, restarted a regular cycle, immediately opened the front door and saw water flowing in through the internal inlet. This exercise tells me the water level sensor was not an issue because it did not have a chance to be activated at low water level, therefore, the problem must be with the "water inlet valve". I found on www an info that one should test conductivity between the two power terminals on the valve (after unplugging the connectors); if it shows open circuit then the valve is bad. Is that a right test? Is it the part I should be focused on or there is some other piece I must investigate?
Thank you,
V
Ads By Google
Related Models
Whirlpool KUDS03CTSS0 Undercounter Dishwasher
Whirlpool KUDS03CTSS1 Undercounter Dishwasher
Whirlpool KUDS03CTSS2 Undercounter Dishwasher
Whirlpool KUDS03CTWH0 Undercounter Dishwasher
Whirlpool KUDS03CTWH1 Undercounter Dishwasher
Whirlpool KUDS03CTWH2 Undercounter Dishwasher
Whirlpool KUDS03FSBL1 Undercounter Dishwasher
Whirlpool KUDS03FSBL2 Undercounter Dishwasher
Whirlpool KUDS03FSBL3 Undercounter Dishwasher
Whirlpool KUDS03FSBL4 Undercounter Dishwasher
Whirlpool KUDS03FSBT1 Undercounter Dishwasher
Whirlpool KUDS03FSBT2 Undercounter Dishwasher
Whirlpool KUDS03FSBT3 Undercounter Dishwasher
Whirlpool KUDS03FSBT4 Undercounter Dishwasher
Whirlpool KUDS03FSSS1 Undercounter Dishwasher
Whirlpool KUDS03FSSS2 Undercounter Dishwasher
Whirlpool KUDS03FSSS3 Undercounter Dishwasher
Whirlpool KUDS03FSSS4 Undercounter Dishwasher
Whirlpool KUDS03FSWH1 Undercounter Dishwasher
Whirlpool KUDS03FSWH2 Undercounter Dishwasher
Whirlpool KUDS03FSWH3 Undercounter Dishwasher
Whirlpool KUDS03FSWH4 Undercounter Dishwasher
Whirlpool KUDS03FTBL0 Undercounter Dishwasher
Whirlpool KUDS03FTBL1 Undercounter Dishwasher
Whirlpool KUDS03FTBL2 Undercounter Dishwasher
Whirlpool KUDS03FTBT0 Undercounter Dishwasher
Whirlpool KUDS03FTBT1 Undercounter Dishwasher
Whirlpool KUDS03FTBT2 Undercounter Dishwasher
Whirlpool KUDS03FTPA0 Undercounter Dishwasher
Whirlpool KUDS03FTPA1 Undercounter Dishwasher
Whirlpool KUDS03FTPA2 Undercounter Dishwasher
Whirlpool KUDS03FTSS0 Undercounter Dishwasher
Whirlpool KUDS03FTSS1 Undercounter Dishwasher
Whirlpool KUDS03FTSS2 Undercounter Dishwasher
Whirlpool KUDS03FTWH0 Undercounter Dishwasher
Whirlpool KUDS03FTWH1 Undercounter Dishwasher
Whirlpool KUDS03FTWH2 Undercounter Dishwasher
Whirlpool KUDS03STBL0 Undercounter Dishwasher
Whirlpool KUDS03STBL1 Undercounter Dishwasher
Whirlpool KUDS03STBL2 Undercounter Dishwasher
Whirlpool KUDS03STSS0 Undercounter Dishwasher
Whirlpool KUDS03STSS1 Undercounter Dishwasher
Whirlpool KUDS03STSS2 Undercounter Dishwasher
Whirlpool KUDS03STWH0 Undercounter Dishwasher
Whirlpool KUDS03STWH1 Undercounter Dishwasher
Whirlpool KUDS03STWH2 Undercounter Dishwasher
Whirlpool KUDS21CS0
Whirlpool KUDS21CS1
Whirlpool KUDS21CS2
Whirlpool KUDS21MS0
Whirlpool KUDS21MS1
Whirlpool KUDS21MS2
Whirlpool KUDS21MS3
Whirlpool KUDS21SS0
Whirlpool KUDS21SS1
Whirlpool KUDS21SS2
Whirlpool KUDS220ST0
Whirlpool KUDS220T0
Whirlpool KUDS220T1
Whirlpool KUDS220T2
Whirlpool KUDS220T3
Whirlpool KUDS220T4
Whirlpool KUDS220T5
Whirlpool KUDS22CT0
Whirlpool KUDS22HT0
Whirlpool KUDS22HT1
Whirlpool KUDS22ST0
Whirlpool KUDS22ST1
Whirlpool KUDS230B0
Whirlpool KUDS230BAL0
Whirlpool KUDS230BWH0
Whirlpool KUDS230Y0
Whirlpool KUDS230Y1
Whirlpool KUDS230Y2
Whirlpool KUDS23HB0
Whirlpool KUDS23HBAL0
Whirlpool KUDS23HBWH0
Whirlpool KUDS23HY0
Whirlpool KUDS23HY1
Whirlpool KUDS23HY2
Whirlpool KUDS24SEAL0
Whirlpool KUDS24SEAL1
Whirlpool KUDS24SEAL2
Whirlpool KUDS24SEAL3
Whirlpool KUDS24SEAL4
Whirlpool KUDS24SEAL5
Whirlpool KUDS24SEBL0
Whirlpool KUDS24SEBL1
Whirlpool KUDS24SEBL2
Whirlpool KUDS24SEBL3
Whirlpool KUDS24SEBL4
Whirlpool KUDS24SEBL5
Whirlpool KUDS24SEBS0
Whirlpool KUDS24SEBS1
Whirlpool KUDS24SEBS3
Whirlpool KUDS24SEBS4
Whirlpool KUDS24SEBS5
Whirlpool KUDS24SEBT0
Whirlpool KUDS24SEBT4
Whirlpool KUDS24SEBT5
Whirlpool KUDS24SEWH0
Whirlpool KUDS24SEWH1
Whirlpool KUDS24SEWH2
Whirlpool KUDS24SEWH3
Whirlpool KUDS24SEWH4
Whirlpool KUDS24SEWH5
Whirlpool KUDS25SHAL0
Whirlpool KUDS25SHAL1
Whirlpool KUDS25SHBL0
Whirlpool KUDS25SHBL1
Whirlpool KUDS25SHBS0
Whirlpool KUDS25SHBS1
Whirlpool KUDS25SHBT0
Whirlpool KUDS25SHBT1
Whirlpool KUDS25SHWH0
Whirlpool KUDS25SHWH1
Whirlpool KUDT03FTBL0 Undercounter Dishwasher
Whirlpool KUDT03FTBL1 Undercounter Dishwasher
Whirlpool KUDT03FTBL2 Undercounter Dishwasher
Whirlpool KUDT03FTPA0 Undercounter Dishwasher
  #2 (permalink)
Old 10-02-2012, 09:35 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
You have diagnosed it correctly especially since you removed power from the unit and the valve did not close.
You need to replace the following.
Part number: AP4429566
__________________
  #3 (permalink)
Old 10-02-2012, 10:05 AM
Junior Member
Default
Thank you, Danman. I have removed the valve and tested conductivity between the terminals, the circuit is closed. I guess, the mechanical parts of the valve itself must be defective...
Also, I compared the original with the picture of part AP4429566 and noticed the hose connector on the valve of the original unit is perpendicular to the solenoid, while the replacement is parallel. I am concerned that the available space between the dishwasher's frame and the valve will not allow me to connect and fit the hose without a 90 degree elbow. Is there an identical replica of the original unit available at all?
Brgds,
V
  #4 (permalink)
Old 10-02-2012, 02:37 PM
Senior Expert
APP Volunteer
Default
I would be best to give the parts pros at AppliancePartsPros a call
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
KitchenAid Superba Ice maker water won't stop running and is overflowing! jhschlak Refrigerator & Freezer Repair 12 12-16-2011 12:09 PM
Bosch SHE45M Dishwasher not taking water nusscat Dishwasher Repair 0 06-20-2011 05:30 AM
KitchenAid dishwasher taking too long jim97219 Dishwasher Repair 1 03-10-2011 10:37 AM
KitchenAid Dryer taking several cycles to dry clothes tlaffey Dryer Repair 3 01-05-2010 06:42 AM
bosch dishwasher wont run after taking in water decshark Dishwasher Repair 5 11-05-2008 03:49 PM
