| » Bosch Dishwasher Stuck on 1 never stops |
Model Number: shu5316uc/06 Brand: Bosch Age: 5 - 10 years
I recently replaced the control unit and float assembly. When I first ran the unit after replacing these parts it started at some cycle number and it went down to 1 but it never stopped. The unit just kept washing and didn't finish the cycle. I then opened the door and let it sit for a few minutes and started the wash cycle again. It then started at 13 on the timer and it went down to 1. Once again it kept going after reaching 1. I let it run and after an hour it finished the cycle.
I started a third cycle and it started at 2H. Once again it went down to 1 but it never stopped washing. I opened it and started the cycle again and again it started at 13 and went to 1 and stayed there for an hour and finished the cycle. I could do this sequence over and over. I also noticed the inside of the unit has a moister film on it as if the water didn't get very hot. I know the water form my water heater is coming in hot because I actually ran the water several minutes before starting each of the cycles to make sure I had hot water. I also ran a vinegar rinse to clean the sensors per one of the posts, just in case. I am wondering if the heater assembly may be bad and be causing this problem. Ads By Google Related Models |
Thanks for your response Mark. It turns out heater was bad on it. I went through the trouble shoot manual and figured it out. As you said I replaced the entire assemble and it worked fine. Unfortunately it probably means the original controller was fine and I ended up buying a new one but I guess I have a spare in case the new one goes out.
Thanks again. |
| Display Modes | |
| Bosch Dishwasher Stuck on 2H | SeattlePete | Dishwasher Repair | 37 | 03-23-2013 09:02 AM |
| bosch dishwasher getting stuck | dennisdebonis | Dishwasher Repair | 0 | 07-21-2011 11:34 AM |
| Bosch dishwasher stuck on | Ken N | Dishwasher Repair | 0 | 08-29-2010 12:00 PM |
| Bosch Dishwasher Stuck in Was | jreading | Dishwasher Repair | 0 | 03-20-2010 01:12 PM |
| My Bosch dishwasher is stuck! | kevin e | Dishwasher Repair | 5 | 04-04-2008 05:09 PM |
