Discuss
bosch dishwasher question shu4302uc
 in
Dishwasher Repair
Thanks for the documentation, but what i really need to know is how to chk the NTC cause there two
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » bosch dishwasher question shu4302uc
  #31 (permalink)
Old 11-06-2012, 10:42 AM
Junior Member
melissourgos is on a distinguished road
Post
chk the NTC cause there two sets of wires going to it (2 red and 2 green). can you please tell me how to chk that? Thanks.
  #32 (permalink)
Old 11-06-2012, 11:29 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The instructions are attached.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #33 (permalink)
Old 11-06-2012, 06:31 PM
Junior Member
Post
This is what I came up with starting at the lowest ohm setting and moving up if needed.
Heater: OL at all settings
Flow switch removed from the heater : 000.0 ohms
NTC: 57.8 Kohms
Hi-limit: never got stable to one setting and ranged between 14 and .4 ohms.
I did the NTC and Hi-limit test with the sensor still attached to the heater.
  #34 (permalink)
Old 11-07-2012, 12:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
How did you check the heater? Did you remove the wires? If you did then the heater is bad.
- The heater assembly Part number: 264462
Part number: 264462
__________________
  #35 (permalink)
Old 11-07-2012, 08:43 PM
Junior Member
Post
yes the wires were removed.
does the bottom of the dishwasher need to be removed to replace the heater?
  #36 (permalink)
Old 11-09-2012, 06:11 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm afraid you have not read all files attached to the posts earlier. Open the file from the post at 11/01 please.
__________________
  #37 (permalink)
Old 11-28-2012, 02:46 PM
Junior Member
Post
I replaced the heater and the machine it goes thru the cycle without any
problems. But it does not desolve all the detergent in the dispenser.
This is odd cause it has never done this before. If you have any suggestions please let me know. Thank you very much for all your help.
  #38 (permalink)
Old 11-28-2012, 04:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What kind of detergent did you use?
Open the door during the wash cycle to check how much water is inside and post the result.
__________________
  #39 (permalink)
Old 11-28-2012, 05:42 PM
Junior Member
Post
If that model has 3 washing arms then I am missing one the one on the roof of the machine. That would explain why it does not clear the dispenser cause it does not build up enough pressure. Pls let me know.
  #40 (permalink)
Old 11-28-2012, 06:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by melissourgos View Post
...If that model has 3 washing arms...
Did you see any signs of such third arm? I did not see it on the diagrams.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch dishwasher dispenser question ghstudio Dishwasher Repair 0 07-14-2011 02:55 PM
Bosch dishwasher question aelst Dishwasher Repair 4 05-15-2010 07:26 PM
Bosch Dishwasher Question rjtoolne Dishwasher Repair 1 04-05-2010 05:58 PM
Bosch Dishwasher question pitbull_dad Dishwasher Repair 0 03-03-2010 02:21 PM
