Discuss
Dishwasher
 in
Dishwasher Repair
My dishwasher starts the cycle and goes through the whole cycle, but never drains. I used to be able to
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher
  #1 (permalink)
Old 09-23-2009, 01:35 PM
Junior Member
lborough is on a distinguished road
Default Dishwasher
Brand: GE   Age: 1 - 5 years
My dishwasher starts the cycle and goes through the whole cycle, but never drains. I used to be able to hear it kick in when it started draining, but this never happens now......what could possibly be wrong. I don't have a stopped up drain, already checked for that. Thanks.
  #2 (permalink)
Old 09-23-2009, 08:42 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A Model Number may help others help you
On most GE's
Remove the kick plate.
On the left hand front side of the pump you will see a solenoid.
This is the wash/drain solenoid.
It should pull down when the unit is supposed to drain.
With the unit off see if you can activate it manually.
Note the solenoid only gets power for about 10 seconds and then the water pressure holds the flapper valve in the drain position till the machine is empty. The spring then returns the valve to the wash position.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
