Discuss
blinking clean light - what to check next
 in
Dishwasher Repair
I'm new to this forum and need some help on where to go from here on my repair of the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » blinking clean light - what to check next
  #1 (permalink)
Old 09-21-2012, 08:24 AM
Junior Member
signal is on a distinguished road
Default blinking clean light - what to check next
Model Number: GU2700XTSYO   Brand: Whirlpool   Age: 5 - 10 years
I'm new to this forum and need some help on where to go from here on my repair of the Whirlpool Quiet Partner IV.
Aside from the familiar blinking clean light, the symptoms are that the dishes are not as dry or hot as they had been before the blinking light first started. And the plastics are just plain wet.
There was still water in the bottom of the dishwasher, so I cleaned out the chopper and drain assembly. It was pretty clogged, but I still get the blinking clean light even after clearing the code. The blinking lights return about every fifth load but all the loads are the same with dishes that are a little wet and plastics that are very wet. They are also not hot, kind of warm.
The heater element has a small blister on it. Could it be as easy as replacing the heater element? I just don't want to throw parts at the dishwasher.
Thanks, George
Ads By Google
Related Models
Whirlpool GU3200XTPB0 Undercounter Dishwasher
Whirlpool GU3200XTPB1 Undercounter Dishwasher
Whirlpool GU3200XTPB3 Undercounter Dishwasher
Whirlpool GU3200XTPB4 Undercounter Dishwasher
Whirlpool GU3200XTPB5 Undercounter Dishwasher
Whirlpool GU3200XTPQ0 Undercounter Dishwasher
Whirlpool GU3200XTPQ1 Undercounter Dishwasher
Whirlpool GU3200XTPQ3 Undercounter Dishwasher
Whirlpool GU3200XTPQ4 Undercounter Dishwasher
Whirlpool GU3200XTPQ5 Undercounter Dishwasher
Whirlpool GU3200XTPS0 Undercounter Dishwasher
Whirlpool GU3200XTPS1 Undercounter Dishwasher
Whirlpool GU3200XTPS3 Undercounter Dishwasher
Whirlpool GU3200XTPS4 Undercounter Dishwasher
Whirlpool GU3200XTPS5 Undercounter Dishwasher
Whirlpool GU3200XTSB0 Undercounter Dishwasher
Whirlpool GU3200XTSB1 Undercounter Dishwasher
Whirlpool GU3200XTSB2 Undercounter Dishwasher
Whirlpool GU3200XTSQ0 Undercounter Dishwasher
Whirlpool GU3200XTSQ1 Undercounter Dishwasher
Whirlpool GU3200XTSQ2 Undercounter Dishwasher
Whirlpool GU3200XTSS0 Undercounter Dishwasher
Whirlpool GU3200XTSS1 Undercounter Dishwasher
Whirlpool GU3200XTSS2 Undercounter Dishwasher
Whirlpool GU3600XTRB0 Undercounter Dishwasher
Whirlpool GU3600XTRB1 Undercounter Dishwasher
Whirlpool GU3600XTRQ0 Undercounter Dishwasher
Whirlpool GU3600XTRQ1 Undercounter Dishwasher
Whirlpool GU3600XTRY0 Undercounter Dishwasher
Whirlpool GU3600XTRY1 Undercounter Dishwasher
Whirlpool GU3600XTSB0 Undercounter Dishwasher
Whirlpool GU3600XTSB1 Undercounter Dishwasher
Whirlpool GU3600XTSB2 Undercounter Dishwasher
Whirlpool GU3600XTSQ0 Undercounter Dishwasher
Whirlpool GU3600XTSQ1 Undercounter Dishwasher
Whirlpool GU3600XTSQ2 Undercounter Dishwasher
Whirlpool GU3600XTSY0 Undercounter Dishwasher
Whirlpool GU3600XTSY1 Undercounter Dishwasher
Whirlpool GU3600XTSY2 Undercounter Dishwasher
Whirlpool GU630XTLQ0 Undercounter Dishwasher
Whirlpool GU630XTLQ1 Undercounter Dishwasher
Whirlpool GU640XTLQ0 Undercounter Dishwasher
Whirlpool GU640XTLQ1 Undercounter Dishwasher
Whirlpool GU940SCGB0
Whirlpool GU940SCGB1
Whirlpool GU940SCGB2
Whirlpool GU940SCGB3
Whirlpool GU940SCGQ0
Whirlpool GU940SCGQ1
Whirlpool GU940SCGQ2
Whirlpool GU940SCGQ3
Whirlpool GU940SCGT3
Whirlpool GU940SCGZ0
Whirlpool GU940SCGZ1
Whirlpool GU940SCGZ2
Whirlpool GU940SCGZ3
Whirlpool GU960SCGB0
Whirlpool GU960SCGQ0
Whirlpool GU980QPDB0
Whirlpool GU980QPDQ0
Whirlpool GU980QPDZ0
Whirlpool GU980SCGB0
Whirlpool GU980SCGB1
Whirlpool GU980SCGB2
Whirlpool GU980SCGB3
Whirlpool GU980SCGQ0
Whirlpool GU980SCGQ1
Whirlpool GU980SCGQ2
Whirlpool GU980SCGQ3
Whirlpool GU980SCGS1
Whirlpool GU980SCGS2
Whirlpool GU980SCGS3
Whirlpool GU980SCGT2
Whirlpool GU980SCGT3
Whirlpool GU980SCGZ0
Whirlpool GU980SCGZ1
Whirlpool GU980SCGZ2
Maytag GV1110PRW Range - F/s Std Gas
International GV1226NXEW Freezer - Vertical
International GV1726NXEW Freezer - Vertical
Hoover GV3177WUA Range - F/s Std Gas
Hoover GV3177WUA5 Range - F/s Std Gas
Hoover GV3177WUW Range - F/s Std Gas
Hoover GV3177WUW5 Range - F/s Std Gas
Maytag GV3277XUA Range - F/s Std Gas
Maytag GV3277XUW Range - F/s Std Gas
Hoover GV3531WUA Range - F/s Std Ele
Hoover GV3531WUW Range - F/s Std Ele
Whirlpool GVW9959KL0
Whirlpool GVW9959KL1
Whirlpool GVW9959KL2
Whirlpool GVW9959KL3 Automatic Washer
Whirlpool GVW9959KQ0
Whirlpool GVW9959KQ1
Whirlpool GVW9959KQ2
Whirlpool GVW9959KQ3 Automatic Washer
Whirlpool GVW9959KT0
Whirlpool GVW9959KT1
Whirlpool GVW9959KT2
Whirlpool GVW9959KT3 Automatic Washer
Maytag GW18F1 Washer - Top Loading
Maytag GW18F1A Washer - Top Loading
Maytag GW18F1H Washer - Top Loading
Maytag GW18F1W Washer - Top Loading
Maytag GW18F2 Washer - Top Loading
Maytag GW18F2A Washer - Top Loading
Maytag GW18F2H Washer - Top Loading
Maytag GW18F2W Washer - Top Loading
Maytag GW18G1 Washer - Top Loading
Maytag GW18G100 Washer - Top Loading
Maytag GW18G124 Washer - Top Loading
Maytag GW18G125 Washer - Top Loading
Maytag GW18G1A Washer - Top Loading
Maytag GW18G1HW Washer - Top Loading
Maytag GW18G1WW Washer - Top Loading
Maytag GW20F6 Washer - Top Loading
Maytag GW20F600 Washer - Top Loading
Maytag GW20F624 Washer - Top Loading
Maytag GW20F625 Washer - Top Loading
Maytag GW20F6A Washer - Top Loading
  #2 (permalink)
Old 09-22-2012, 09:39 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for Whirlpool GU2700XTSY0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
See the attachment for the tech sheet
Yes it could.
Remove power from the unit and one wire from the heating element.
Then measure the element with a meter, should be between 10 and 30 ohms.
You may as well also check the high limit thermostat, it should be 0 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
  #3 (permalink)
Old 09-22-2012, 11:38 AM
Junior Member
Default
It was the heater element. All is hot and dry now. Thanks for your response to my question.
  #4 (permalink)
Old 09-23-2012, 05:05 AM
Senior Expert
APP Volunteer
Default
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
clean light blinking groovymom8662 Dishwasher Repair 1 04-01-2012 06:47 AM
Blinking Clean Light CJ1959 Oven Repair (including Ranges and Cooktops) 1 11-16-2010 09:08 PM
Clean light blinking Kristyjo Dryer Repair 0 07-01-2010 07:15 PM
clean light keeps blinking goodnurse Dishwasher Repair 4 01-17-2010 12:23 PM
check lint light blinking lichtfuss Dryer Repair 1 09-25-2008 05:33 PM
