Discuss
Kenmore Dishwasher Model: 665.13443k900
 in
Dishwasher Repair
Hello and thank you. This dishwasher suddenly quit in the middle of use. I have located a blown thermal fuse
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore Dishwasher Model: 665.13443k900
  #1 (permalink)
Old 09-18-2012, 04:37 PM
Junior Member
ender7 is on a distinguished road
Default Kenmore Dishwasher Model: 665.13443k900
Model Number: 665.13443k900   Brand: Kenmore   Age: 5 - 10 years
I have located a blown thermal fuse in the door up by the control panel (photo included).
Normally, I only use the 'Normal Wash' setting. The last time, when it quit, I had used 'Heavy Wash', 'High Temp', 'Sani-Rinse' settings.
It quit leaving a lot of water in the bottom so I guess it must have been in a wash cycle?
I am wondering if there is something that caused it to draw too much current causing the fuse to go out. The power to the dishwasher is excellent and the connections look good.
Is it possible that the heating element is weak and drawing too much current at high settings? Will a continuity test show higher resistance if it works fine on a lower setting but is going bad and can't handle higher setting?
Does the heating element pull out from the inside or must it be removed from underneath? (I am trying to avoid having to shut the water off because of the way it was installed and cannot access the rear unless I do).
Before I replace the fuse I want to try to see if there is anything else to check that might be a weak link.
Thank you very much for your assistance.
[COLOR=#000000 ! important][/color]
Ads By Google
Related Models
Kenmore 665.1350190  COMPACTOR
Kenmore 665.1350191  COMPACTOR
Kenmore 665.1350192  COMPACTOR
Kenmore 665.1350193  COMPACTOR
Kenmore 665.1350194  COMPACTOR
Kenmore 665.1350195  COMPACTOR
Kenmore 665.1350196  COMPACTOR
Kenmore 665.1350590  COMPACTOR
Kenmore 665.1350591  COMPACTORS
Kenmore 665.1350592  COMPACTOR
Kenmore 665.1350593  COMPACTOR
Kenmore 665.1350594  COMPACTORS
Kenmore 665.1350595  COMPACTOR
Kenmore 665.1350596  COMPACTOR
Kenmore 665.1358550  TRASH COMPACTOR
Kenmore 665.1358551  TRASH COMPACTOR
Kenmore 665.13601790  COMPACTOR
Kenmore 665.13603000  COMPACTORS
Kenmore 665.13604000  COMPACTORS
Kenmore 665.13605790  COMPACTOR
Kenmore 665.13608790  COMPACTOR
Kenmore 665.13612100  COMPACTORS
Kenmore 665.13613100  COMPACTORS
Kenmore 665.13614100  COMPACTORS
Kenmore 665.13619100  COMPACTORS
Kenmore 665.1386580  TRASH COMPACTOR
Kenmore 665.1386581  TRASH COMPACTOR
Kenmore 665.1386582  COMPACTOR
Kenmore 665.1388550  TRASH COMPACTOR
Kenmore 665.1388580  TRASH COMPACTOR
Kenmore 665.1388581  TRASH COMPACTOR
Kenmore 665.1388582  COMPACTOR
Kenmore 665.1396580  TRASH COMPACTOR
Kenmore 665.1396581  TRASH COMPACTOR
Kenmore 665.1396582  COMPACTOR
Kenmore 665.4098450  BUILT-IN OVEN
Kenmore 665.4098451  RANGE - ELEC
Kenmore 665.4098452  BUILT-IN OVEN
Kenmore 665.4098890  ELECTRIC BUILT-IN OVEN
Kenmore 665.4098910  ELEC. BUILT-IN OVEN
Kenmore 665.4098911  BUILT IN-ELEC. OVEN
Kenmore 665.4098912  BUILT-IN OVEN
Kenmore 665.4098913  BUILT-IN OVEN
Kenmore 665.4098914  ELEC. BUILT-IN OVEN
Kenmore 665.4098915  ELECTRIC BUILT-IN OVEN
Kenmore 665.4098990  BUILT IN WALL OVEN
Kenmore 665.4098991  BUILT-IN ELEC. OVEN
Kenmore 665.4098992  BUILT-IN OVEN
Kenmore 665.4098993  BUILT-IN OVEN
Kenmore 665.4098994  ELEC. BUILT-IN OVEN
Kenmore 665.4098995  ELECTRIC BUILT-IN OVEN
Kenmore 665.4098996  RANGE - ELEC
Kenmore 665.4098997  BUILT IN OVEN
Kenmore 665.42500  KENMORE COMPACTOR
Kenmore 665.42501  KENMORE COMPACTOR
Kenmore 665.42550  KENMORE COMPACTOR
Kenmore 665.42551  KENMORE COMPACTOR
Kenmore 665.42600  KENMORE COMPACTOR
Kenmore 665.42601  KENMORE COMPACTOR
Kenmore 665.427303-1  COMPACTOR
Kenmore 665.427303-2  COMPACTOR
Kenmore 665.427303-3  COMPACTOR
Kenmore 665.427303-4  COMPACTOR
Kenmore 665.427303-5  COMPACTOR
Kenmore 665.4428451  RANGE - ELEC
Kenmore 665.4428996  ELECTRIC DOUBLE OVEN BUILT-IN
Kenmore 665.4428997  RANGE - ELEC KENMORE
Kenmore 665.4428998  BUILT IN OVEN
Kenmore 665.4433450  BUILT-IN OVEN AND MICROWAVE
Kenmore 665.4433451  BUILT IN OVEN WITH MICROWAVE OVEN
Kenmore 665.4433452  ELEC BUILT-IN OVEN / MICROWAVE
Kenmore 665.4438890  MICRO/ELECTRIC BUILT-IN OVEN
Kenmore 665.4438913  BUILT-IN OVEN/MICRO
Kenmore 665.4438990  MICROWAVE OVEN
Kenmore 665.4438995  BUILT-IN OVEN/MICRO
Kenmore 665.4493392  MICROWAVE
Kenmore 665.4493393  ELEC BUILT-IN OVEN AND MICROWAVE
Kenmore 665.4558953  ELECTRIC COOKTOP / BUILT-IN OVEN
Kenmore 665.4558995  ELECTRIC COOKTOP
Kenmore 665.45755690  30" ELECTRIC DROP-IN RANGE
Kenmore 665.45755691  30" ELECTRIC DROP-IN RANGE
Kenmore 665.45759690  30" ELECTRIC DROP-IN RANGE
Kenmore 665.45759691  30" ELECTRIC DROP-IN RANGE
Kenmore 665.4579351  ELECTRIC RANGE
Kenmore 665.4579391  BUILT-IN RANGE
Kenmore 665.60601000  MICROWAVE/HOOD COMBO
Kenmore 665.60609000  MICROWAVE/HOOD COMBO
Kenmore 665.60612000  MICROWAVE/HOOD COMBO
Kenmore 665.60617000  MICROWAVE/HOOD COMBO
Kenmore 665.60619000  MICROWAVE/HOOD COMBO
Kenmore 665.60622000  MICROWAVE/HOOD COMBO
Kenmore 665.60629000  MICROWAVE/HOOD COMBO
Kenmore 665.60632000  MICROWAVE/HOOD COMBO
Kenmore 665.60639000  MICROWAVE/HOOD COMBO
Kenmore 665.60652000  MICROWAVE/HOOD COMBO
Kenmore 665.60654000  MICROWAVE/HOOD COMBO
Kenmore 665.60657000  MICROWAVE/HOOD COMBO
Kenmore 665.60659000  MICROWAVE/HOOD COMBO
Kenmore 665.60682000  MICROWAVE/HOOD COMBO
Kenmore 665.60689000  MICROWAVE/HOOD COMBO
Kenmore 665.61601100  MICROWAVE
Kenmore 665.61609100  MICROWAVE
Kenmore 665.61612100  MICROWAVE/HOOD COMBO
Kenmore 665.61614100  MICROWAVE/HOOD COMBO
Kenmore 665.61617100  MICROWAVE/HOOD COMBO
Kenmore 665.61619100  MICROWAVE/HOOD COMBO
Kenmore 665.61622100  MICROWAVE/HOOD COMBO
Kenmore 665.61624100  MICROWAVE/HOOD COMBO
Kenmore 665.61627100  MICROWAVE/HOOD COMBO
Kenmore 665.61629100  MICROWAVE/HOOD COMBO
Kenmore 665.61632100  MICROWAVE/HOOD COMBO
Kenmore 665.61639100  MICROWAVE/HOOD COMBO
Kenmore 665.61652100  MICROWAVE/HOOD COMBO
Kenmore 665.61652101  MICROWAVE/HOOD COMBO
Kenmore 665.61652102  MICROWAVE/HOOD COMBO
Kenmore 665.61654100  MICROWAVE/HOOD COMBO
Kenmore 665.61654101  MICROWAVE/HOOD COMBO
Kenmore 665.7042700  SEARS COMPACTOR
Kenmore 665.7042701  KENMORE COMPACTOR
Kenmore 665.7242600  SEARS KENMORE COMPACTOR
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore dishwasher model# 58715142402 will not work. noodles1976 Dishwasher Repair 1 06-25-2012 01:45 PM
Kenmore Ultra Wash Dishwasher Model 665.1737 Scmore Dishwasher Repair 1 03-16-2012 03:59 AM
Kenmore model 665 dishwasher detergent door rpb763 Dishwasher Repair 1 09-25-2011 02:07 PM
Kenmore Dishwasher Model # Castrok Dishwasher Repair 6 08-01-2010 08:08 PM
Kenmore dishwasher model 587.1618 2400 charlsnchrg757 Dishwasher Repair 0 03-10-2009 02:18 PM
