Discuss
Bosch Dishwasher problems
 in
Dishwasher Repair
When I turn the machine on the timer starts at 13 on all wash cycles rather than the normal start
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dishwasher problems
  #1 (permalink)
Old 09-15-2012, 10:14 AM
Junior Member
Manuel Arce is on a distinguished road
Default Bosch Dishwasher problems
Model Number: shu5316uc/06   Brand: Bosch   Age: More than 10 years
When I turn the machine on the timer starts at 13 on all wash cycles rather than the normal start time. The timer then counts down to 1 and it stalls there until I have to manually turn it off. The unit never fills with water but there is a motor running the entire time.
I replaced the control unit with one I purchased from Appliance Pros and I had the same problems. The control starts at 13 for all wash cycles and counts down to 1 and stalls except with the new control unit no motor comes on at all. Yes I installed the jumper on the new unit. In fact I purchased a new jumper and then I used the old jumper to check if it made a difference.
I have also changed the pressure chamber assembly.
I recently downloaded the trouble shooting manual and started checking some of the components. The first one I checked so far is the inlet valve. I measured the resistance on it and it has just under 1000 ohms (996) I assume that is close enough to determine it is fine. I turned the unit on and measured the voltage across the valve terminals and I am not getting any reading. So that means the control unit is not sending a turn on signal to the valve. I still don't know if that is because the control unit is bad or if there is another sensor out telling the unit it is full of water and therefore it starts at 13 minutes.
Ads By Google
Related Models
Bosch SHU5317 UC/12
Bosch SHU53A02 UC/14 (FD 8211-)
Bosch SHU53A05 UC/14 (FD 8211-)
Bosch SHU53A06 UC/14 (FD 8211-)
Bosch SHU53E02 UC/14 (FD 8211-)
Bosch SHU53E05 UC/14 (FD 8211-)
Bosch SHU53E06 UC/14 (FD 8211-)
Whirlpool SHU55000
Whirlpool SHU55010
Whirlpool SHU55040
Whirlpool SHU55041
Whirlpool SHU55042
Whirlpool SHU60010
Whirlpool SHU60011
Whirlpool SHU60020
Bosch SHU66C02 UC/14 (FD 8211-)
Bosch SHU66C05 UC/14 (FD 8211-)
Bosch SHU66C06 UC/14 (FD 8211-)
Bosch SHU66C07 UC/14 (FD 8211-)
Bosch SHU66E02 UC/14 (FD 8211-)
Bosch SHU66E05 UC/14 (FD 8211-)
Bosch SHU66E06 UC/14 (FD 8211-)
Bosch SHU66E07 UC/14 (FD 8211-)
Bosch SHU6802 UC/06 (FD 7705-7912)
Bosch SHU6802 UC/11 (FD 8001-8003)
Bosch SHU6802 UC/12 (FD 8003-)
Bosch SHU6805 UC/06 (FD 7705-7912)
Bosch SHU6805 UC/11 (FD 8001-8003)
Bosch SHU6805 UC/12 (FD 8003-)
Bosch SHU6806 UC/06 (FD 7705-7912)
Bosch SHU6806 UC/11 (FD 8001-8003)
Bosch SHU6806 UC/12 (FD 8003-)
Whirlpool SHU70000
Whirlpool SHU70001
Whirlpool SHU70010
Whirlpool SHU70040
Whirlpool SHU70041
Whirlpool SHU70050
Whirlpool SHU70051
Whirlpool SHU70052
Whirlpool SHU75000
Whirlpool SHU75010
Whirlpool SHU75040
Whirlpool SHU75042
Whirlpool SHU80000
Whirlpool SHU80001
Whirlpool SHU80010
Whirlpool SHU80040
Whirlpool SHU80041
Whirlpool SHU80042
Bosch SHU8802 UC/12 (FD 8105-)
Bosch SHU8805 UC/12 (FD 8105-)
Bosch SHU8806 UC/12 (FD 8105-)
Bosch SHU8812 UC/12 (FD 8105-)
Bosch SHU8815 UC/12 (FD 8105-)
Bosch SHU8816 UC/12 (FD 8105-)
Whirlpool SHU90000
Whirlpool SHU90001
Whirlpool SHU90002
Whirlpool SHU90010
Whirlpool SHU90040
Whirlpool SHU90041
Whirlpool SHU90050
Whirlpool SHU99000
Whirlpool SHU99001
Bosch SHU9902 UC/06
Bosch SHU9902 UC/06 (FD 7905-7912)
Whirlpool SHU99040
Whirlpool SHU99041
Bosch SHU9905 UC/06
Bosch SHU9905 UC/06 (FD 7905-7912)
Whirlpool SHU99050
Whirlpool SHU99052
Whirlpool SHU99053
Bosch SHU9906 UC/06
Bosch SHU9906 UC/06 (FD 7905-7912)
Bosch SHU9912 UC/06
Bosch SHU9912 UC/06 (FD 7908-8002)
Bosch SHU9912 UC/11
Bosch SHU9912 UC/11 (FD 8002-8003)
Bosch SHU9912 UC/12
Bosch SHU9912 UC/12 (FD 8003-)
Bosch SHU9915 UC/06
Bosch SHU9915 UC/06 (FD 7908-8002)
Bosch SHU9915 UC/11
Bosch SHU9915 UC/11 (FD 8002-8003)
Bosch SHU9915 UC/12
Bosch SHU9915 UC/12 (FD 8003-)
Bosch SHU9916 UC/06
Bosch SHU9916 UC/06 (FD 7908-8002)
Bosch SHU9916 UC/11
Bosch SHU9916 UC/11 (FD 8002-8003)
Bosch SHU9916 UC/12
Bosch SHU9916 UC/12 (FD 8003-)
Bosch SHU9922 UC/12 (FD 8003-)
Bosch SHU9925 UC/12 (FD 8003-)
Bosch SHU9926 UC/12 (FD 8003-)
Bosch SHU9952 UC/12 (FD 8105 -)
Bosch SHU9955 UC/12 (FD 8105 -)
Bosch SHU9956 UC/12 (FD 8105 -)
Bosch SHV4303 UC/06
Bosch SHV4303 UC/06 (FD 7712-8002)
Bosch SHV4303 UC/11
Bosch SHV4303 UC/11 (FD 8002-8003)
Bosch SHV4303 UC/12
Bosch SHV4303 UC/12 (FD 8003-)
Bosch SHV46C03 UC/14 (FD 8211-)
Bosch SHV4803 UC/06
Bosch SHV4803 UC/06 (FD 7712-7812, 7905-7907)
Bosch SHV4803 UC/07
Bosch SHV4803 UC/07 (FD 7812-7905, 7907-8010)
Bosch SHV4803 UC/12
Bosch SHV4803 UC/12 (FD 8010-)
Bosch SHV66A03 UC/14 (FD 8301-)
Bosch SHV6803 UC/12 (FD 8105 -)
Bosch SHV99A03 UC/14 (FD 8212-)
Hoover SHWA2501A Washer - Top Loading
Hoover SHWA2501W Washer - Top Loading
Hoover SHWA2506A Washer - Top Loading
Hoover SHWA2506AT Washer - Top Loading
  #2 (permalink)
Old 09-16-2012, 03:33 PM
Junior Member
Default
I happen to come across a post that made a suggestion to fill the washer with water and run it. This solved the problem. It started at 13 and kept going down to 1 where it ran for over an hour but it completed the cycle with complete draining of the water and everything. I then started a second cycle and it started at 76 and went the through the complete cycle.
Problem solved!!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch SHU43C02UC/14 fill problems sparky296 Washer Repair 1 06-30-2011 07:26 PM
Bosch Dishwasher-?Pump problems Kmartino Dishwasher Repair 0 04-10-2011 12:35 PM
Bosch SHU3326UC problems McGoo Dishwasher Repair 1 09-23-2010 09:04 PM
Bosch dishwasher won't drain, power surge problems? vcalkins Dishwasher Repair 9 08-23-2008 10:51 AM
Bosch Problems jopa Dishwasher Repair 1 03-25-2008 06:51 PM
