Discuss
Low pressure, stalling during cycle, PF code
 in
Dishwasher Repair
Hello, Im new here. I have an interesting problem. The Frigidaire dishwasher is not pumping water at full pressure and
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Low pressure, stalling during cycle, PF code
  #1 (permalink)
Old 09-11-2012, 01:13 PM
Junior Member
agast is on a distinguished road
Default Low pressure, stalling during cycle, PF code
Model Number: GLDB958JB0   Brand: Frigidaire   Age: 5 - 10 years
Hello, Im new here.
I have an interesting problem. The Frigidaire dishwasher is not pumping water at full pressure and quits running at times. Any thoughts would be appreciated. Here is the scenario.
First off the unit started flashing a PF code on the display at times like when the power goes off but all the clocks in the house were not flashing as if its just the dishwasher loosing power...
Then it started stalling during the wash cycle and I think displayed the PF code as well.
I recently replaced the latch and handle but that shouldn't cause power failures Id think..? Though the door doesn't close as tightly as before, but it doesn't leak anywhere.
Then it started running with little or no pressure. I clicked the latch open on the door so the machine would run with the door open. It fills with water normally, starts to cycle with a little water squirting a couple inches out of the bottom sprayer only then would loose all pressure and stop squirting. The pump runs what sounds like normally. Thinking the pump was clogged. I took the screens out and the inside impeller cover off, it was all clean, the impeller looked good and turned freely.. I ran the unit again and stuck my finger in the opening to the impeller with the cover back on. The impeller spins but I can stop it easily with little pressure pushing on the center of the shaft and it turns at maybe 100 rpm. Are there speeds controlled by the computer?
My first reaction was to replace the pump motor, but with the PF codes and shut downs, I wonder if the control board isnt sending the right signals. I turned off the power to it, like a reboot for 10 seconds but no change.
It does empty after the cycle, fyi. Thoughts? Testing the voltage to the motor? Continuity on the motor? If I have to buy both a motor and a controller, It may be better to buy a new dishwasher. Well thanks so much for your time and reading this long post..
Ads By Google
Related Models
Frigidaire GLDB958JB0
Frigidaire GLDB958JB1 Frigidaire/dishwasher
Frigidaire GLDB958JS0
Frigidaire GLDB958JS1 Frigidaire/dishwasher
Frigidaire GLDB958JT0
Frigidaire GLDB958JT1 Frigidaire/dishwasher
Whirlpool GLE5700XSN0
Whirlpool GLE5700XSW0
Whirlpool GLE7900XKW0
Whirlpool GLE7900XMW0
Whirlpool GLE7900XMW1
Whirlpool GLE7900XMW2
Whirlpool GLE7900XMW3
Frigidaire GLEB27M9EBA Frigidaire/wall Oven - Microwave Combo
Frigidaire GLEB27M9EBB Frigidaire/wall Oven
Frigidaire GLEB27M9EQA Frigidaire/wall Oven - Microwave Combo
Frigidaire GLEB27M9EQB Frigidaire/wall Oven
Frigidaire GLEB27M9ESA Frigidaire/wall Oven - Microwave Combo
Frigidaire GLEB27M9ESB Frigidaire/wall Oven
Frigidaire GLEB27M9FBA Frigidaire/microwave - Walloven Combo
Frigidaire GLEB27M9FBB Frigidaire/wall Oven
Frigidaire GLEB27M9FQA Frigidaire/microwave - Walloven Combo
Frigidaire GLEB27M9FQB Frigidaire/wall Oven
Frigidaire GLEB27M9FSA Frigidaire/microwave - Walloven Combo
Frigidaire GLEB27M9FSB Frigidaire/wall Oven
Frigidaire GLEB27S7ABA Frigidaire/electric Range
Frigidaire GLEB27S7ASA Frigidaire/electric Range
Frigidaire GLEB27S7CBA Frigidaire/electric Wall Oven
Frigidaire GLEB27S7CBB Frigidaire/electric Wall Oven
Frigidaire GLEB27S7CSA Frigidaire/electric Wall Oven
Frigidaire GLEB27S7CSB Frigidaire/electric Wall Oven
Frigidaire GLEB27S9DBA Frigidaire/electric Walloven
Frigidaire GLEB27S9DBB Frigidaire/wall Oven
Frigidaire GLEB27S9DQA Frigidaire/electric Walloven
Frigidaire GLEB27S9DQB Frigidaire/wall Oven
Frigidaire GLEB27S9DSA Frigidaire/electric Walloven
Frigidaire GLEB27S9DSB Frigidaire/wall Oven
Frigidaire GLEB27S9FBA Frigidaire/walloven
Frigidaire GLEB27S9FQA Frigidaire/walloven
Frigidaire GLEB27S9FSA Frigidaire/walloven
Frigidaire GLEB27T8ABA Frigidaire/electric Wall Oven
Frigidaire GLEB27T8ABB Frigidaire/electric Wall Oven
Frigidaire GLEB27T8ASA Frigidaire/electric Wall Oven
Frigidaire GLEB27T8ASB Frigidaire/electric Wall Oven
Frigidaire GLEB27T8ASC Frigidaire/wall Oven
Frigidaire GLEB27T8CBA Frigidaire/electric Wall Oven
Frigidaire GLEB27T8CSA Frigidaire/electric Wall Oven
Frigidaire GLEB27T9DBA Frigidaire/electric Walloven
Frigidaire GLEB27T9DBB Frigidaire/wall Oven
Frigidaire GLEB27T9DBC Frigidaire/walloven
Frigidaire GLEB27T9DQA Frigidaire/electric Walloven
Frigidaire GLEB27T9DQB Frigidaire/wall Oven
Frigidaire GLEB27T9DQC Frigidaire/walloven
Frigidaire GLEB27T9DSA Frigidaire/electric Walloven
Frigidaire GLEB27T9DSB Frigidaire/wall Oven
Frigidaire GLEB27T9DSC Frigidaire/walloven
Frigidaire GLEB27T9FBA Frigidaire/wall Oven
Frigidaire GLEB27T9FQA Frigidaire/wall Oven
Frigidaire GLEB27T9FSA Frigidaire/wall Oven
Frigidaire GLEB30M9EBA Frigidaire/wall Oven/microwave Combo
Frigidaire GLEB30M9EBC Frigidaire/wall Oven/microwave
Frigidaire GLEB30M9EQA Frigidaire/wall Oven/microwave Combo
Frigidaire GLEB30M9EQC Frigidaire/wall Oven/microwave
Frigidaire GLEB30M9ESA Frigidaire/wall Oven/microwave Combo
Frigidaire GLEB30M9ESC Frigidaire/wall Oven/microwave
Frigidaire GLEB30M9FBA Frigidaire/wall Oven/microwave
Frigidaire GLEB30M9FQA Frigidaire/wall Oven/microwave
Frigidaire GLEB30M9FSA Frigidaire/wall Oven/microwave
Frigidaire GLEB30S8ABA Frigidaire/electric Range
Frigidaire GLEB30S8AQA Frigidaire/electric Range
Frigidaire GLEB30S8ASA Frigidaire/electric Range
Frigidaire GLEB30S8ASB Frigidaire/electric Wall Oven
Frigidaire GLEB30S8CBA Frigidaire/electric Wall Oven
Frigidaire GLEB30S8CBB Frigidaire/wall Oven
Frigidaire GLEB30S8CQA Frigidaire/electric Wall Oven
Frigidaire GLEB30S8CQB Frigidaire/wall Oven
Frigidaire GLEB30S8CSA Frigidaire/electric Wall Oven
Frigidaire GLEB30S8CSB Frigidaire/wall Oven
Frigidaire GLEB30S9DBA Frigidaire/walloven
Frigidaire GLEB30S9DBB Frigidaire/electric Walloven
Frigidaire GLEB30S9DBD Frigidaire/wall Oven
Frigidaire GLEB30S9DQA Frigidaire/walloven
Frigidaire GLEB30S9DQB Frigidaire/electric Walloven
Frigidaire GLEB30S9DQD Frigidaire/wall Oven
Frigidaire GLEB30S9DSA Frigidaire/walloven
Frigidaire GLEB30S9DSB Frigidaire/electric Walloven
Frigidaire GLEB30S9DSD Frigidaire/wall Oven
Frigidaire GLEB30S9FBA Frigidaire/wall Oven
Frigidaire GLEB30S9FBB Frigidaire/walloven
Frigidaire GLEB30S9FQA Frigidaire/wall Oven
Frigidaire GLEB30S9FQB Frigidaire/walloven
Frigidaire GLEB30S9FSA Frigidaire/wall Oven
Frigidaire GLEB30S9FSB Frigidaire/walloven
Frigidaire GLEB30T8ABA Frigidaire/electric Wall Oven
Frigidaire GLEB30T8ASA Frigidaire/electric Wall Oven
Frigidaire GLEB30T8ASB Frigidaire/wall Oven
Frigidaire GLEB30T8CBA Frigidaire/electric Wall Oven
Frigidaire GLEB30T8CSA Frigidaire/electric Wall Oven
Frigidaire GLEB30T8DQA Frigidaire/electric Wall Oven
Frigidaire GLEB30T9DBA Frigidaire/electric Walloven
Frigidaire GLEB30T9DBB Frigidaire/wall Oven
Frigidaire GLEB30T9DBC Frigidaire/wall Oven
Frigidaire GLEB30T9DBD Frigidaire/wall Oven
Frigidaire GLEB30T9DQA Frigidaire/electric Walloven
Frigidaire GLEB30T9DQB Frigidaire/wall Oven
Frigidaire GLEB30T9DQC Frigidaire/wall Oven
Frigidaire GLEB30T9DQD Frigidaire/wall Oven
Frigidaire GLEB30T9DSA Frigidaire/electric Walloven
Frigidaire GLEB30T9DSB Frigidaire/wall Oven
Frigidaire GLEB30T9DSC Frigidaire/wall Oven
Frigidaire GLEB30T9DSD Frigidaire/wall Oven
Frigidaire GLEB30T9FBA Frigidaire/walloven
Frigidaire GLEB30T9FBB Frigidaire/walloven
Frigidaire GLEB30T9FQA Frigidaire/walloven
Frigidaire GLEB30T9FQB Frigidaire/walloven
Frigidaire GLEB30T9FSA Frigidaire/walloven
Frigidaire GLEB30T9FSB Frigidaire/walloven
Frigidaire GLEC30S8ABB Frigidaire/electric Cooktop
Frigidaire GLEC30S8ABC Frigidaire/electric Cooktop
Frigidaire GLEC30S8AQA Frigidaire/cooktop
  #2 (permalink)
Old 09-11-2012, 02:20 PM
Junior Member
Default
I did notice the water level in the unit was only 1/4 inch above the 12" round metal filter screen thats on the bottom. So the low pressure may be from a low water level but the power failures may be separate...
I just read a thread that adding hot water to the tub up to the float switch may verify the pump is ok if it starts washing at normal pressure.
The inlet valve screen may need to be checked or the timer is bad if it stops filling in less than 80-90 seconds... though that was for a different model.
  #3 (permalink)
Old 09-11-2012, 06:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You may want to measure the voltage to the motor while the control calls for wash. Also check the power cord connections to the dishwasher. It can be loose.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #4 (permalink)
Old 09-12-2012, 11:21 AM
Junior Member
Default
Thanks, I suppose I just disconnect the leads to the motor. Is it 120v to the motor or is there a transformer that steps down the voltage? Thanks!
  #5 (permalink)
Old 09-12-2012, 01:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It should to be about 120 VAC.
__________________
  #6 (permalink)
Old 09-16-2012, 12:27 PM
Junior Member
Default
Hello,
It took a couple days to get to it but I tested the leads going to the pump and it had 120v on the white and blue wires. So I checked the motor terminals for continuity and the white and blue wire terminals had 4 ohms resistance. the green wire terminal had no reading when testing with the other two terminals, the meter did not move. I ran the washer again with the bottom panel removed and the electric motor would buzz and sounded odd like it was laboring. No or little water would come from the spray arm. Also, could the intermittant PF code be due to a motor short?
Thanks again for your input.
  #7 (permalink)
Old 09-17-2012, 06:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The motor has to be replaced. It comes as a part of the pump & motor kit. In regards of "PF" error code: did you check the power cord connections?
- The pump & motor kit Part number: 154859501
__________________
  #8 (permalink)
Old 09-17-2012, 06:19 PM
Junior Member
Default
Hi Gene,
I was unable to get to the power connections, Its in a rental and I only had a little time to get in there over the weekend. After pricing the pump and an inlet valve i am only $80 from buying a new Whirlpool or a Kenmore.. I hear Whirlpool is the brand to buy...? Would love to see a post one what is the brand to buy.
Im now thinking repairing this dishwasher a third time may not be feasible. Its 10 years old. Ive bought my previous parts from App and will continue too when I decide to fix what breaks. Thanks for your feedback.
  #9 (permalink)
Old 09-18-2012, 08:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You might be right. It's probably not worth to fix it. Whirlpool dishwashers are much better than Frigidaire in my opinion. I would not by Kenmore because you don't know who really made it and it could be another one made by Frigidaire.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Oasis--loud spin cycle--water pressure? love2box Washer Repair 1 12-24-2011 08:11 AM
stalling nestorone Washer Repair 1 02-10-2011 06:47 PM
timer stalling Helpmewyo Washer Repair 0 10-31-2010 08:27 AM
Sears Electric Dryer Stalling Joe Cioletti Dryer Repair 2 08-31-2010 03:01 AM
Need Help In Stalling Dial-therm mred63 Oven Repair (including Ranges and Cooktops) 1 03-27-2009 02:08 PM
