Discuss
Leak by impeller by pump housing
 in
Dishwasher Repair
Hi, I have a leak occurring underneath my Whirlpool dishwasher Model DU890DWGU2. I have pin pointed the leak by the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Leak by impeller by pump housing
  #1 (permalink)
Old 09-07-2012, 03:21 PM
Junior Member
mtnbike86 is on a distinguished road
Default Leak by impeller by pump housing
Model Number: DU890DWGU2   Brand: Whirlpool   Age: More than 10 years
I have a leak occurring underneath my Whirlpool dishwasher Model DU890DWGU2. I have pin pointed the leak by the pump impeller area. I am wondering if I would need only to replace the worn parts with the Impeller/seal kit Part #AP3108052 or would I need more parts?
Is there also a step my step instruction or video on how to accomplish this task online?
Thanks mtnbike86
Ads By Google
Related Models
Whirlpool DU890DWGU2
Whirlpool DU890DWGX0
Whirlpool DU890DWGX1
Whirlpool DU890DWGZ0
Whirlpool DU890DWGZ1
Whirlpool DU890DWGZ2
Whirlpool DU890SWKQ0
Whirlpool DU890SWKT0
Whirlpool DU890SWKU0
Whirlpool DU890SWLQ0 Undercounter Dishwasher
Whirlpool DU890SWLTO Undercounter Dishwasher
Whirlpool DU890SWLU0 Undercounter Dishwasher
Whirlpool DU8920XX0
Whirlpool DU8950XB0
Whirlpool DU8950XB1
Whirlpool DU8950XT0
Whirlpool DU8950XT1
Whirlpool DU8950XT2
Whirlpool DU8950XT3
Whirlpool DU8950XX0
Whirlpool DU8950XY0
Whirlpool DU8950XY1
Whirlpool DU8950XY2
Whirlpool DU895SWPB0 Undercounter Dishwasher
Whirlpool DU895SWPQ0 Undercounter Dishwasher
Whirlpool DU895SWPS0 Undercounter Dishwasher
Whirlpool DU895SWPT0 Undercounter Dishwasher
Whirlpool DU895SWPU0 Undercounter Dishwasher
Whirlpool DU8960XB0
Whirlpool DU8960XB1
Whirlpool DU8960XY0
Whirlpool DU8960XY1
Magic Chef DU8J Dishwasher - Undercounter
Whirlpool DU9000XR0
Whirlpool DU9000XR1
Whirlpool DU9000XR2
Whirlpool DU9000XR3
Whirlpool DU9000XR4
Whirlpool DU9000XR5
Whirlpool DU9000XR6
Whirlpool DU9000XR7
Whirlpool DU9000XR8
Whirlpool DU9000XR9
Whirlpool DU900PCDB0
Whirlpool DU900PCDB2
Whirlpool DU900PCDB3
Whirlpool DU900PCDB4
Whirlpool DU900PCDB5
Whirlpool DU900PCDB6
Whirlpool DU900PCDQ0
Whirlpool DU900PCDQ2
Whirlpool DU900PCDQ3
Whirlpool DU900PCDQ4
Whirlpool DU900PCDQ5
Whirlpool DU900PCDQ6
Whirlpool DU900PCDZ0
Whirlpool DU900PCDZ2
Whirlpool DU900PCDZ3
Whirlpool DU900PCDZ4
Whirlpool DU900PCDZ5
Whirlpool DU900PCDZ6
Whirlpool DU900PWKB0
Whirlpool DU900PWKQ0
Whirlpool DU900PWKT0
Amana DU9010B Dishwasher - Undercounter
Amana DU9010W Dishwasher - Undercounter
Whirlpool DU909PWKB0 Undercounter Dishwasher
Whirlpool DU909PWKQ0 Undercounter Dishwasher
Whirlpool DU909PWKT0 Undercounter Dishwasher
Magic Chef DU90A-01 Dishwasher - Undercounter
Magic Chef DU90A-02 Dishwasher - Undercounter
Whirlpool DU9100XT0
Whirlpool DU9100XT1
Whirlpool DU9100XT4
Whirlpool DU910PFGB0
Whirlpool DU910PFGB1
Whirlpool DU910PFGQ0
Whirlpool DU910PFGQ1
Whirlpool DU910PFGZ0
Whirlpool DU910PFGZ1
Whirlpool DU910PWKB0
Whirlpool DU910PWKQ0
Whirlpool DU911PCDB0
Whirlpool DU911PCDQ0
Whirlpool DU911PWKB0
Whirlpool DU911PWKQ0
Whirlpool DU912PFGB0
Whirlpool DU912PFGB1
Whirlpool DU912PFGB2
Whirlpool DU912PFGQ0
Whirlpool DU912PFGQ1
Whirlpool DU912PFGQ2
Whirlpool DU912PFGT2
Whirlpool DU912PFGZ0
Whirlpool DU912PFGZ1
Whirlpool DU912PFGZ2
Whirlpool DU915PWKB0
Whirlpool DU915PWKQ0
Whirlpool DU915PWKS0
Whirlpool DU915PWKT0
Whirlpool DU915PWPB0 Undercounter Dishwasher
Whirlpool DU915PWPB1 Undercounter Dishwasher
Whirlpool DU915PWPB2 Undercounter Dishwasher
Whirlpool DU915PWPQ0 Undercounter Dishwasher
Whirlpool DU915PWPQ1 Undercounter Dishwasher
Whirlpool DU915PWPQ2 Undercounter Dishwasher
Whirlpool DU915PWPS0 Undercounter Dishwasher
Whirlpool DU915PWPS1 Undercounter Dishwasher
Whirlpool DU915PWPS2 Undercounter Dishwasher
Whirlpool DU915PWPT0 Undercounter Dishwasher
  #2 (permalink)
Old 09-07-2012, 04:02 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
You should be OK with replacing this impeller kit, but you should consider the possible damage to the motor bearings if that leak was for a while. In that case replace the motor/pump assembly.
Here are the breakdown diagrams and Replacement parts for Whirlpool DU890DWGU2 DISHWASHER | AppliancePartsPros.com
Thank you.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 10-16-2012, 09:25 AM
Junior Member
fstdrvr2 is on a distinguished road
Default
Thanks mtnbike86
If it's making a grinding noise, which it usually is by the time you notice the leak, you will need to replace the entire pump/motor assembly. If you are really handy and have the tools and patience, you can disassemble the motor and replace the front bearing in the motor and use the impeller seal kit. Whirlpool won't sell the bearing or the motor, so you will have to buy one at a bearing shop. Closest one I have found is 6082RS. You will have to cut the old one off the shaft and sand it down to get the new bearing onto it. Alot of work! If you can afford it and want to save on the frustration, just replace the entire pump/motor assembly.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Leaking around the impeller shaft to the pump housing MarshDoit Dishwasher Repair 2 07-26-2011 07:04 AM
filter leak from housing henry4 Refrigerator & Freezer Repair 0 03-18-2011 06:21 PM
new pump or impeller kit Jan Reeves Dishwasher Repair 3 12-06-2010 08:09 AM
won't pump to top impeller mdied Dishwasher Repair 3 04-21-2010 03:49 PM
Impeller jams on plastic housing dfeldbaum Dishwasher Repair 3 12-04-2008 10:03 PM
