gums
#1 Posted : Tuesday, September 22, 2009 1:23:31 PM(UTC)
gums
There is no heat during the drying cycle. The element "looks" OK.
Are there thermostats or something else to look at as a culprit before I invest in a new heating element? If so what may they be and where would I locate them in the dishwasher?
I am an amateur repair guy. Would I be better off calling Maytag?
#2 Posted : Wednesday, September 23, 2009 1:33:36 AM(UTC)
Replacement parts for DW860 models | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16007822.pdf
Just because it looks OK does not mean that it is OK. Best to check it with a meter.
See Page 3-16 in the manual
Cannot say, depends on whether you have the time to repair/check it.
gums
#3 Posted : Wednesday, September 23, 2009 5:42:03 AM(UTC)
gums
I'll give it a go. Time is my best commodity.
Maytag jetclean dishwasher does not dry dishes? (Dishwasher Repair)
by SNAFUHL 4/9/2010 9:42:55 AM(UTC)
Dishwasher does not dry dishes (Dishwasher Repair)
by mbreuhaus 3/2/2010 12:47:49 PM(UTC)
dishwasher does not dry dishes (Dishwasher Repair)
by yensmavahoj 8/24/2008 9:04:20 PM(UTC)
