Discuss
Bosch DW spray arms not turning
 in
Dishwasher Repair
My Bosch dishwasher stopped cleaning its loads a few days ago, and I determined that the spray arms were not
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch DW spray arms not turning
  #1 (permalink)
Old 08-28-2012, 03:10 PM
Junior Member
Max Headroom is on a distinguished road
Default Bosch DW spray arms not turning
Brand: Bosch   Age: 1 - 5 years
My Bosch dishwasher stopped cleaning its loads a few days ago, and I determined that the spray arms were not turning. I know all the basics so I removed the filters and cleaned them, took all the spray arms off along with the riser tube, checked that everything was clean and clear and then ran a cycle with the filter parts in the rack and a heavy vinegar load.
No dice; the bottom arm turns rather slowly, but the upper one does not turn at all, or only in small jumps. Both spin freely. Both are cleaned out and clear. There is definitely water running through the spray arm system; as always, I am having trouble determining whether it's the usual amount or "enough."
The one thing that seems wonky is that a LOT of water is coming out of the top spray head - when you snap the door open, that's where the overspray and splash come from. It LOOKS as if too much water is exiting up there, but I can't see anything wrong with the spray head - nothing is broken or obviously missing. However, the spray gaps are pretty big, maybe half big enough to slide a nickel through, and I wonder if some additional spray or blocking element is missing.
Anyone have a detailed photo or drawing of the late-model, higher-end Bosch top spray head? Or other ideas about why the arms wouldn't be spinning even though there is a pretty fair water flow through the spray arm tubes?
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch does not pump water to spray arms Richard Rose Dishwasher Repair 0 11-30-2010 08:40 AM
GE Quiet Power III spray arms not turning alw Dishwasher Repair 4 11-08-2008 05:05 AM
Bosch Spray Arms not Spraying jjfrett Dishwasher Repair 4 02-07-2008 10:20 AM
spray arms not turning jon6180 Dishwasher Repair 1 01-17-2008 03:50 PM
