My dishwasher door is sagging low when fully opened, to the point where the bottom rack does not roll out smoothly any longer. I know I have to replace the hinges, but I also suspect there is another problem as it did this when the hinges were fine also. What would cause this symptom and also, what are the steps to replacing a hinge?
