I have the clean light flashing 7X's then repeating. I cannot run diagnostics to clear this light. When I press the resume button I can hear what sounds like the drain motor running (there is no water inside) and will run for maybe a minute or so then shut off. Unplugging makes no difference. Heating element measures approx: 20 ohms
