I searched this site and found a possible explanation regarding leaking at the door, or around the door. The possible problems listed were:
1. Using to much soap. (3 n 1 Electrasol tablets/squares) 2. Leak from the wash arm 3. Leak in the doors dispensers
My trouble shooting actions: 1. I ran the dishwasher without the 3-n-1 Electrasol. And to my surprise, there was a lot of suds!! And it leaked. So, I ran a 2nd time without soap, and it leaked, but not as bad - only half the water the 2nd time. So, I am running it a 3rd time without soap to see if it does it again.... 2. I also cleaned the corner baffles really well, and wiped down the door gasket too. 3. Visually, I didn't see any holes in the wash arm, or around the door dispenser. So, if the leak continues I'll focus on the dispensers. 4. And I have noticed that the leak must begin from the middle to end of the cycle period?
If I still have leaking after the 3rd wash cycle without soap added, any idea what it could be?
