Kitchen aid superba model Kuds01fkss0 fl2902257 Hi Pro The dishwasher leaks through the bottom of the door when in use. I replaced Door gasket kit - Door seal repair kit comes with black rubber seal, adhesive and instruction Part Number: AP3672571 made by WHIRLPOOL I have a new Air inlet Part Number: AP3085279 made by WHIRLPOOL which I have not installed. I have Seal - Located between console and door. Part Number: AP3799148 made by WHIRLPOOL which I dont have instructions on how and where it is to be replaced. Could give me installation instructions for that seal Located between console and door - What else could be causing the leak ???? Thank you
