My Bosch was showing 52 minutes left in cycle the other day but no noise was being made. I opened the door and it sounded like it was trying to pull out water although there was no sitting water inside. I reset the machine (held the two 'cancel drain' buttons down) and opened the door and hit "off". the machine turned off as normal and i tried a new load using regular cycle. the minutes showed on both the LED on front and on the top of the door, as usual, but when I closed the door the LED minutes on front shut off after a few seconds. They continued counting down as normal on top of the door but the machine itself wasn't doing anything, basically just counting down the minutes. When I opened the door that original noise of the machine trying to pull out water returned although it never even went into a presoak or any other cycle.
Seems very strange. Thoughts? :(
