Discuss
Do I need a new pump / motor
 in
Dishwasher Repair
I thoroughly cleaned out sump, impeller, and housing around impeller. Replaced housing and filters. With wash arm off, the pump
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Do I need a new pump / motor
  #1 (permalink)
Old 08-12-2012, 03:05 PM
Junior Member
Rokefuller is on a distinguished road
Default Do I need a new pump / motor
Model Number: FDB126RBS2   Brand: Frigidaire   Age: 5 - 10 years
I thoroughly cleaned out sump, impeller, and housing around impeller. Replaced housing and filters. With wash arm off, the pump would produce a column of water almost as high as the top of the inside of the cabinet. After about five seconds the column of water dwindled and completely dropped off to nothing. I removed the filters and housing again to make sure the impeller was not plugged and was actually turning. Would a bad o-ring between the recirculation side and discharge side of the pump cause this problem? There were also chunks of a plasticized material in the sump discharge filter basket when I first took the filters out. Is there a sealant or caulking applied to the impeller housing at the factory? Or is there supposed to be more to the impeller than the radial wheel? I did not know if this material was from with in the machine or something the tenant put in the machine.
Related Models
Frigidaire FDB126RBS2 Frigidaire/dishwasher
Frigidaire FDB126RBS3 Frigidaire/dishwasher
Frigidaire FDB126RBS4 Frigidaire/dishwasher
Frigidaire FDB130RGB0 Frigidaire/dishwasher
Frigidaire FDB130RGB1 DISHWASHER
Frigidaire FDB130RGB2 DISHWASHER
Frigidaire FDB130RGB3 DISHWASHER
Frigidaire FDB130RGQ0 Frigidaire/dishwasher
Frigidaire FDB130RGQ1 DISHWASHER
Frigidaire FDB130RGQ2 DISHWASHER
Frigidaire FDB130RGQ3 DISHWASHER
Frigidaire FDB130RGS0 Frigidaire/dishwasher
Frigidaire FDB130RGS1 DISHWASHER
Frigidaire FDB130RGS2 DISHWASHER
Frigidaire FDB130RGS3 DISHWASHER
Frigidaire FDB1450CHB0 DISHWASHER
Frigidaire FDB1450CHB1 DISHWASHER
Frigidaire FDB1450CHB2 DISHWASHER
Frigidaire FDB1450CHB4 DISHWASHER
Frigidaire FDB1450CHC0 DISHWASHER
Frigidaire FDB1450CHC1 DISHWASHER
Frigidaire FDB1450CHC2 DISHWASHER
Frigidaire FDB1450CHC4 DISHWASHER
Frigidaire FDB1450CHS0 DISHWASHER
Frigidaire FDB1450CHS1 DISHWASHER
Frigidaire FDB1450CHS2 DISHWASHER
Frigidaire FDB1450CHS4 DISHWASHER
Frigidaire FDB1500LFB0 Frigidaire/dishwasher
Frigidaire FDB1500LFB1 DISHWASHER
Frigidaire FDB1500LFB2 DISHWASHER
Frigidaire FDB1500LFB4 DISHWASHER
Frigidaire FDB1500LFC0 Frigidaire/dishwasher
Frigidaire FDB1500LFC1 DISHWASHER
Frigidaire FDB1500LFC2 DISHWASHER
Frigidaire FDB1500LFC4 DISHWASHER
Frigidaire FDB1500LFQ0 Frigidaire/dishwasher
Frigidaire FDB1500LFQ1 DISHWASHER
Frigidaire FDB1500LFQ2 DISHWASHER
Frigidaire FDB1500LFQ4 DISHWASHER
Frigidaire FDB1500LFS0 Frigidaire/dishwasher
Frigidaire FDB1500LFS1 DISHWASHER
Frigidaire FDB1500LFS2 DISHWASHER
Frigidaire FDB1500LFS4 DISHWASHER
Frigidaire FDB1501BFB0 Frigidaire/dishwasher
Frigidaire FDB1501BFC0 Frigidaire/dishwasher
Frigidaire FDB1501BFQ0 Frigidaire/dishwasher
Frigidaire FDB1501BFS0 Frigidaire/dishwasher
Frigidaire FDB1502RGB0 Frigidaire/dishwasher
Frigidaire FDB1502RGB1 DISHWASHER
Frigidaire FDB1502RGB2 DISHWASHER
Frigidaire FDB1502RGB4 DISHWASHER
Frigidaire FDB1502RGC0 Frigidaire/dishwasher
Frigidaire FDB1502RGC1 DISHWASHER
Frigidaire FDB1502RGC2 DISHWASHER
Frigidaire FDB1502RGC4 DISHWASHER
Frigidaire FDB1502RGM0 DISHWASHER
Frigidaire FDB1502RGM1 DISHWASHER
Frigidaire FDB1502RGM2 DISHWASHER
Frigidaire FDB1502RGM4 DISHWASHER
Frigidaire FDB1502RGQ0 Frigidaire/dishwasher
Frigidaire FDB1502RGQ1 DISHWASHER
Frigidaire FDB1502RGQ2 DISHWASHER
Frigidaire FDB1502RGQ4 DISHWASHER
Frigidaire FDB1502RGS0 Frigidaire/dishwasher
Frigidaire FDB1502RGS1 DISHWASHER
Frigidaire FDB1502RGS2 DISHWASHER
Frigidaire FDB1502RGS4 DISHWASHER
Frigidaire FDB1504RGB0 DISHWASHER
Frigidaire FDB1504RGC0 DISHWASHER
Frigidaire FDB1504RGQ0 DISHWASHER
Frigidaire FDB1504RGS0 DISHWASHER
Frigidaire FDB1980RGB0 DISHWASHER
Frigidaire FDB1980RGB1 DISHWASHER
Frigidaire FDB1980RGB2 DISHWASHER
Frigidaire FDB1980RGC0 DISHWASHER
Frigidaire FDB1980RGC1 DISHWASHER
Frigidaire FDB1980RGC2 DISHWASHER
Frigidaire FDB1980RGQ0 DISHWASHER
Frigidaire FDB1980RGQ1 DISHWASHER
Frigidaire FDB1980RGQ2 DISHWASHER
Frigidaire FDB1980RGS0 DISHWASHER
Frigidaire FDB1980RGS1 DISHWASHER
Frigidaire FDB1980RGS2 DISHWASHER
Frigidaire FDB2000RFB0 Frigidaire/dishwasher
Frigidaire FDB2000RFB1 Frigidaire/dishwasher
Frigidaire FDB2000RFC0 Frigidaire/dishwasher
Frigidaire FDB2000RFC1 Frigidaire/dishwasher
Frigidaire FDB2000RFQ0 Frigidaire/dishwasher
Frigidaire FDB2000RFQ1 Frigidaire/dishwasher
Frigidaire FDB2000RFS0 Frigidaire/dishwasher
Frigidaire FDB2000RFS1 Frigidaire/dishwasher
Frigidaire FDB200RBW0 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire FDB210LCS0 Frigidaire/dishwasher
Frigidaire FDB2110LCB0 Frigidaire/dishwasher
Frigidaire FDB2110LCC0 Frigidaire/dishwasher
Frigidaire FDB2110LCQ0 Frigidaire/dishwasher
Frigidaire FDB2110LCS0 Frigidaire/dishwasher
Frigidaire FDB212RBM0 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire FDB221RFR0 Frg(v0) / Built - in Dishwasher
Frigidaire FDB221RFR1 Frg(v0) / Built - in Dishwasher
Frigidaire FDB221RFR2 Frg(v0) / 24 " Built - in Dishwasher
Frigidaire FDB221RFR3 Frg(v0) / Dishwasher
Frigidaire FDB2310LCB0 Frigidaire/dishwasher
Frigidaire FDB2310LCC0 Frigidaire/dishwasher
Frigidaire FDB2310LCC1 Frigidaire/dishwasher
Frigidaire FDB2310LCC2 Frigidaire/dishwasher
Frigidaire FDB2310LCQ0 Frigidaire/dishwasher
Frigidaire FDB2310LCS0 Frigidaire/dishwasher
Frigidaire FDB2320REB0 Frigidaire/dishwasher
Frigidaire FDB2320REB1 Frigidaire/dishwasher
Frigidaire FDB2320REB2 Frigidaire/dishwasher
Frigidaire FDB2320REC0 Frigidaire/dishwasher
Frigidaire FDB2320REC1 Frigidaire/dishwasher
Frigidaire FDB2320REC2 Frigidaire/dishwasher
Frigidaire FDB2320RES0 Frigidaire/dishwasher
Frigidaire FDB2320RES1 Frigidaire/dishwasher
Frigidaire FDB2320RES2 Frigidaire/dishwasher
Frigidaire FDB2321REC0 Frigidaire/dishwasher
Frigidaire FDB2321REC1 Frigidaire/dishwasher
Frigidaire FDB232RBR0 Frg(v1) / 24 " Built - in Dishwasher
  #2 (permalink)
Old 08-13-2012, 03:11 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The attached article will explain how the water distribution system in your dishwasher works. Hopefully it will help you to diagnose the problem.
Here are the breakdown diagrams and Replacement parts for Frigidaire FDB126RBS2 Frigidaire/dishwasher | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 08-14-2012, 05:44 AM
Junior Member
Nic2009 is on a distinguished road
Default
Quote:
This would serve as a hunch. I imagine something fell on the heating element, melted and dripped into the water infiltrating your circulation. Plastic utensils are often the source of this type of debris.
Good luck.
Nic.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
need part # for motor greese cap between pump and motor bones0 Washer Repair 1 03-07-2011 06:21 PM
Noisy Whirlpool Dishwasher: Replace just motor or whole pump&motor mdion Dishwasher Repair 7 02-28-2011 01:31 PM
Whirlpool dishwasher parts - replace motor or motor AND pump? dishwasher hums Dishwasher Repair 4 01-04-2011 04:57 AM
Wash motor won't start, bad pump motor capacitor? 65skyturbo Dishwasher Repair 0 07-17-2010 11:58 AM
help pump/motor ezfried Dishwasher Repair 5 03-30-2009 06:16 PM
