| » Will Not Drain |
Model Number: GHD5025F01BB Brand: GE Age: 1 - 5 years
We have water left in the tub at the end of a cycle, I've pulled the drain hose from the sink and watched the water run into a bucket, but it just doesnt empty all the way...
I pulled the sump apart and cleaned it out, man was it yucky in there... but still the same result.... Any ideas? It's almost like the pump just isn't running long enough? is there something else I should clean? Ads By Google Related Models |
Replacement parts for General Electric GHD5025F01BB Dishwasher | AppliancePartsPros.com I would check the piston and nut (Item 564 in Section 1). It is behind the screen filter at the back of the tub. It unscrews. If it does not seal properly then during drain some water leaks back into the tub instead of going out the drain.
__________________
| Display Modes | |
| Dishwasher won't drain, push cancel/drain button will clicking then hum, no draining | bluelakes77 | Dishwasher Repair | 0 | 11-10-2011 09:17 PM |
| Maytag D/W: - drain after wash issue but cancel/drain works fine after.... | diesan2011 | Dishwasher Repair | 0 | 08-10-2011 11:39 AM |
| My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? | ks_becker | Washer Repair | 0 | 08-10-2010 10:25 AM |
| bosch shu9925 - drain pump works, won't drain after cycle | mjbarr | Dishwasher Repair | 0 | 10-16-2009 01:11 PM |
| Timer will only advance to fill and wash not drain (have to manually move to drain) | zibdi1 | Dishwasher Repair | 0 | 06-15-2009 03:47 PM |
