All,
After turning on our dishwasher this morning before leaving for work, I arrived in the afternoon only to find that it had been continuously running all day.
I noticed that the timer would go down to 14, jump up to 20, and keep repeating. The water appears to be heating.
I tried entering the test program mode as outlined in the troubleshooting manual in the sticky, but was not able to enter it. Has the button combination changed for this product? The control module was replaced on this machine 1-2 years ago.
I will attempt to check continuity on the NTC/heater element, but not sure if that is the correct course of action.
Thank you.
Edit: The dishwasher is always on Regular cycle, and it appears that it is stuck while rinsing.
Edit 2: I was able to enter the test program, and the test cycle is currently running with a "1" being displayed while in progress.
Edit 3: Cycle finished, "0" and a flashing circular symbol are present in the countdown timer. The Delay Start, Regular Wash, and Quick Wash lights are flashing on the top of the panel, along with the Wash, Dry, and Clean lights on the front of the panel.
