Discuss
Whirlpool stuck in rinse cycle
 in
Dishwasher Repair
I started the dishwasher one evening last week, only to find it still in the rinse cycle the next morning.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool stuck in rinse cycle
  #1 (permalink)
Old 01-27-2008, 04:53 PM
vegemom vegemom is offline
Junior Member
vegemom is on a distinguished road
Default Whirlpool stuck in rinse cycle
Model Number: DU920pwkq0   Brand: Whirlpool   Age: 5 - 10 years
I started the dishwasher one evening last week, only to find it still in the rinse cycle the next morning. I was able to manually turn the dial and it did drain and shut off normally. I ran it the next day and the water did heat, but it still got stuck in the rinse cycle. Another forum indicated it is probably the timer, but since it is about $100 for the part, I want to know what I can check first to be as certain as possible that a new timer will correct the problem. I have never had to to any repairs to a dishwasher, so I'm starting from scratch. Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-28-2008, 01:03 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check for continuity is the heating element (#13 on the tub break down diagram) and the hi limit thermostat (# 18 on the tub break down diagram).
If there is nothing wrong - replace the timer.
- The part number for the heating element is AP3046634
- The part number for the hi limit thermostat is AP3010530
- The part number for the timer is AP3721799
Here are the break down diagrams for the Whirlpool dishwasher Model DU920PWKQ0
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-28-2008, 02:45 PM
Junior Member
Default
Thank you.. I'll be off to the home store tomorrow morning to buy my ohmmeter and start my testing. Thanks for the detailed advice! Anjanette
  #4 (permalink)
Old 01-28-2008, 09:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Anjanette,
Keep me updated, please.
__________________
  #5 (permalink)
Old 01-30-2008, 09:23 AM
Junior Member
Default
Okay, how do I know how to take the continuity readings and what readings I should be getting??
  #6 (permalink)
Old 01-30-2008, 11:09 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Just click on the "continuity".
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch dishwasher stuck on rinse cycle JDDrake Dishwasher Repair 2 04-05-2008 11:10 AM
Runs rinse cycle all the way through the spin cycle hebirdseye Washer Repair 1 01-20-2008 06:10 PM
stuck in drain cycle kyrboyd Dishwasher Repair 0 12-30-2007 10:27 PM
no water on rinse cycle c4cdlm Washer Repair 3 12-12-2007 04:56 PM
Dishwasher skips the wash cycle and stops at the rinse cycle jasporo Dishwasher Repair 1 11-16-2007 06:12 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
