I Have Bench Tested The Pump Motor Which Was Humming When It Was Installed In The Machine. The Starter And Main Windings Checked Out With The Ohm Meter. I Applied Power To The Motor And It Hummed Like It Did When It Was Installed In The Washer. When I Pushed Down On The Impeller Which Is Sping Loaded The Motor Runs Fine. What Could Cause The Motor Not To Run When Installed In The Machine?
