| » whirlpool gold stuck at 42 mins, need more help |
Model Number: GU1500XTLB3 Brand: Whirlpool Age: 5 - 10 years
[FONT='Calibri','sans-serif']My Whirlpool Gold Quiet Partner II dishwasher, model GU1500XTLB3, gets stuck at 42 minutes in the normal wash cycle. The “sensing” and “water heating” LEDs are lit when this happens. I am able to press the “hi-temp” and “sani-rinse” buttons and then press the “pots and pans” button to advance to the next interval in the cycle. The dishwasher then completes the normal wash cycle without a problem and the dishes come out clean and dry. I have previously opened the dishwasher when it was stuck at the 42 minute mark and the water was VERY hot and the dishes dry fine, so I do not suspect the heating element, but would like guidance on how to test this part with the mulitmeter. I have tested the hi-limit thermostat for continuity and it was fine. I also tested the thermistor for resistance and had a reading of about 50 ohms. What else should I look for AND how should it be tested? Thanks in advance.[/font]
Quote:
- The thermistor Part number: 8269208 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
The normal resistance for the heating element suppose to be between 10-35 Ohms.
If the reading is correct, replace the control board. If the reading is incorrect, replace the heating element. They are different for plastic or stainless steel tubs. If you need the correct part number then post what kind of the tub is in your dishwasher. - The control board Part number: 8564543 Gene.
__________________
| Display Modes | |
| Whirlpool Gold - Dual burner stuck on high | kheg | Oven Repair (including Ranges and Cooktops) | 11 | 10-09-2012 06:32 AM |
| Whirlpool Gold Dual Burner stuck on high | bfdladder10 | Oven Repair (including Ranges and Cooktops) | 1 | 03-08-2011 12:32 PM |
| Whirlpool Gold stuck in wash cycle | ari_c | Washer Repair | 0 | 01-10-2011 09:27 AM |
| whirlpool ref won't run unless unplugged for 5 mins. | tippywanknobi | Refrigerator & Freezer Repair | 5 | 07-02-2010 09:34 PM |
| Stuck in defrost until unplugged for 30 mins | eric0561 | Refrigerator & Freezer Repair | 2 | 02-15-2008 11:57 AM |
