| » Whirlpool dishwasher wont drain |
Model Number: DU810SWPQ3 Brand: Whirlpool Age: 1 - 5 years
I could use some suggestions on this dishwasher..
It was not draining so I took out the hose and sump and check ball.. it was coated with grease and hardened cornbread powder? I even turn the impeller and it does not appear to be stuck at all. I put everything back and ran the dishwasher.. it still would not drain! I am curious to know how to check the check valve for this unit.. It is integraged with Manufacturer Number 8520839.. thanks in advance Ads By Google Related Models |
Does it wash?
Did you clean the ball? Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
washes fine.. just does not drain..
I cleaned the ball and the sump area.. How do I determine if the check valve is good or bad? I may have to take the pump assembly out to check (I hope not).. is there a trick to removing the sprayer assembly? thanks in advance |
How much water is left inside the dishwasher?
Where the drain hose is connected to? Do you have an air gap installed on top of the sink? Gene.
__________________
Disconnect the drain hose from the garbage disposal and put it in a large bucket. Check how it will drain.
Gene. P.S. Did you replace the garbage disposal recently?
__________________
No the garbage disposal is old..
I will put the hose in the bucket and check.. Since I am out of town for a few days.. just curious.. if there was no flow, what should I check next? else what if there was very little flow? |
One more thing you may want to check: does the motor run when the control calls for drain?
__________________
The motor in this dishwasher is reversible what means it turns in opposite direction for drain. Slowly turn the knob. The motor should stop for a few seconds and switch from wash to drain.
__________________
| Display Modes | |
| Whirlpool DW wont drain during cycle-but will if i hit drain after | lowstepside | Dishwasher Repair | 0 | 09-06-2011 11:17 AM |
| ge nautilus dishwasher wont drain and sprayarms wont spin | James Jenkins | Dishwasher Repair | 0 | 07-25-2010 05:59 PM |
| Whirlpool Dishwasher wont drain water | shirump | Dishwasher Repair | 1 | 06-07-2010 06:57 AM |
| Whirlpool dishwasher wont wash or rinse, does drain | ppotman | Dishwasher Repair | 5 | 01-13-2010 09:59 AM |
| whirlpool wont drain | BKC68 | Dishwasher Repair | 2 | 11-16-2009 08:42 PM |
