Dishwasher Has No Power
The dishwasher was working fine.
I hadn't used it in awhile and now I close the door and press the button. No lights, No Power. We did the reset. Turned breaker off for a day. It did not fix it. We tested the fuse. That is fine. Power going in and out, at least 125 volts Tested the door switch. That is fine. Power going in and out, at least 125 volts There is power going into the circuit board. It doesn't come out. What else should we test? Thanks, Alex |
Hi Alex,
The model number you posted is incomplete. Verify and repost it please. Gene. |
Model Number
Model KUDS03CTSS3
1 Attachment(s)
Most likely the problem is a bad control board.
Perform the "Checking keypad operation" test as described in the attached Tech sheet. Post the results. Here are the breakdown diagrams and Replacement parts for Whirlpool KUDS03CTSS3 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com Gene. |
| All times are GMT -7. The time now is 11:30 AM. |
