Don Holden
#1 Posted : Tuesday, September 15, 2009 1:48:30 PM(UTC)
Don Holden
The element tested good at Sears, but it does not heat. I have passed every fuse and switch I can find, but it does not heat. Any suggestions?
Thank you.
#2 Posted : Tuesday, September 15, 2009 2:48:53 PM(UTC)
Here are the parts for a DU810CWDB0
Replacement parts for WHIRLPOOL DU810CWDB0 | AppliancePartsPros.com
And the wiring/timer diagram
http://www.servicematters.com/d...0Sheet%20-%203373597.pdf
If the heater is good and the fuse is good and it does not heat either for drying or heating the water then all that is left is a bad wire or the timer
