Discuss
Chopper Assembly protector/cover stuck?
 in
Dishwasher Repair
I need to check the chopper blade assembly in my Kitchenaid KUDS01IJWHO but can not remove the protector/cover part
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Chopper Assembly protector/cover stuck?
  #1 (permalink)
Old 01-26-2008, 11:14 AM
skip skip is offline
Junior Member
skip is on a distinguished road
Default Chopper Assembly protector/cover stuck?
Model Number: KUDS01IJWHO   Brand: Kitchen Aid   Age: 1 - 5 years
I need to check the chopper blade assembly in my Kitchenaid KUDS01IJWHO but can not remove the protector/cover part PS392941. I've removed the torx screws and the top protector shield and can not get the protector covering the chopper assembly to budge. What am I doing wrong?
Thank you.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-26-2008, 01:44 PM
ripleys ripleys is offline
Senior Expert
APP Volunteer
ripleys is on a distinguished road
Default
It's stuck on!!!
Sweet talk it a little and you may have to use a flat blade screwdriver to pry on it GENTLY to loosen it.
If the torx screws are out it should lt should lift off. Use a turkey baster to remove any existing water (makes it easier to see everything) and make sure your model doesn't have a plastic clip holding it on.
  #3 (permalink)
Old 01-26-2008, 01:56 PM
Junior Member
Default
Thanks for replying. It sure is stuck - I've been prying - and not too gently either. Still no luck. I tried the turkey baster, but it's like trying to bail out a boat with holes - more water keeps coming in. I removed the screw on the left side of the cover - are there other screws on the cover itself?
  #4 (permalink)
Old 01-26-2008, 01:59 PM
Senior Expert
APP Volunteer
Default
I think there are two screws one is down behind the chopper cover under the water. That's why I suggested to get ALL the water out so you can see everything.
  #5 (permalink)
Old 01-26-2008, 02:19 PM
Junior Member
Default
Success at last - I used a hairdryer and once the part warmed up it popped off.
  #6 (permalink)
Old 01-27-2008, 05:06 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If the chopper is clogged up, order a new chopper and check valve near the chopper and stuck in the pump base.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
screws for cover sfcasko Dishwasher Repair 1 01-10-2008 06:14 PM
Fan Cover Hans Refrigerator & Freezer Repair 0 01-05-2008 08:45 AM
Block Cover Assembly lisalisa Dryer Repair 1 01-01-2008 02:57 AM
Cover lsoleary Dishwasher Repair 1 10-10-2007 03:14 PM
surge protector onecutup Refrigerator & Freezer Repair 0 08-01-2007 07:51 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
