| » Quiet Partner III wont start |
Model Number: GU2275XTVB0 Brand: Whirlpool Age: 1 - 5 years
our dishwasher will not start. The only button working on the control panel is the Cancel/Drain which will come on for a few second and go off. No other buttons are working. Do I need to replace the electronic control board part #W10130967? or is there a way to check if the board is bad? What else could be wrong?
Do the following:
1. Unplug dishwasher or disconnect power. 2. Open the dishwasher door. 3. Open console and disconnect the keypad ribbon connection from the control (at P1). Make sure all other connections are made. 4. Put console back together. Do not close the dishwasher door. 5. Plug in dishwasher or reconnect power. 6. Wait 5 sec. 7. Close dishwasher door. 8. Monitor the control’s response: If the control is OK (no longer sees shorts with the keypad unplugged), it will respond by turning on the Drain Motor for 2 minutes. Replace the keypad if the control responds OK. If the control is not OK (still sees shorts with the keypad unplugged), then the drain motor will NOT turn on. If the drain motor does not start within 10 sec, then replace the control. - The control board Part number: W10285180 If you need the correct part number for the console, post the color of it. Here are the breakdown diagrams and Replacement parts for Whirlpool GU2275XTVB0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Whirlpool Gold Quiet Partner III Reset Control Panel but still won't start | sandi.gibson | Dishwasher Repair | 0 | 02-22-2012 09:11 PM |
| Wirlpool Quiet Partner II Won't Start | dwgluvnman | Dishwasher Repair | 0 | 08-13-2011 02:36 PM |
| quiet partner II wont respond | robin lala | Dishwasher Repair | 1 | 01-26-2011 04:29 PM |
| Whirlpool Quiet Partner III won't start | Birdieal | Dishwasher Repair | 1 | 08-12-2009 02:23 PM |
| Whirlpool Quiet Partner III won't start | gesworthy | Dishwasher Repair | 4 | 05-19-2009 06:26 PM |
