Discuss
Bosch Dishwasher quit running
 in
Dishwasher Repair
Hi, my wife went to start our Dishwasher (Bosch SMU7056UC/14) yesterday and it did not run/start properly. The unit just
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dishwasher quit running
  #1 (permalink)
Old 06-17-2012, 04:40 PM
Junior Member
jalthof@centurytel.net is on a distinguished road
Default Bosch Dishwasher quit running
Model Number: SMU7056   Brand: Bosch   Age: More than 10 years
Hi, my wife went to start our Dishwasher (Bosch SMU7056UC/14) yesterday and it did not run/start properly. The unit just was “humming” (electrical sound like the timer is trying to do something). Normally we hear the pump run first followed by water entering the dishwasher but all we hear is the electrical “hummm”. When I reset the dishwasher (hold Rinse&Hold and Quick Wash buttons down at the same time) it seems to me that it is taking much longer than it used to. We haven’t had to reset the cycle for years but I seem to recall that it may have taken 20-30 seconds to reset, but it now takes just over 3-minutes. Again I’m not sure if 3-minutes is normal but just wanted to provide you with that information.
I replaced the water valve in 2005 and before it died you could tell what part was going bad because of the excessive noise.
Any advice or things to test to help me figure out what is wrong will be greatly appreciated.
Thanks.
Jeff
Related Models
Bosch SMU7056 UC/09 (FD 7307-7504)
Bosch SMU7056 UC/09 (FD 7505-7506)
Bosch SMU7056 UC/09 (FD 7507-7902)
Bosch SMU7056 UC/14 (FD 7402-7902)
Bosch SMU7056 UC/14 (FD 7507-7902)
Bosch SMU7056 US/02 (FD 7106-7308)
Bosch SMU7056 US/09 (FD 7210-)
 SMV9165BC MWAVE- MOUNTED OVER RANGE/WO
 SMV9165SC MWAVE- MOUNTED OVER RANGE/WO
Thermador SMW272B BUILT-IN OVEN
Thermador SMW272P BUILT-IN OVEN
Thermador SMW272S BUILT-IN OVEN
Thermador SMW272W BUILT-IN OVEN
Thermador SMW272YB AFTER S/N 8204
Thermador SMW272YS AFTER S/N 8204
Thermador SMW272YW AFTER S/N 8204
Thermador SMW272ZS AFTER S/N 8204
Thermador SMWS72YP AFTER S/N 8204
Bosch SMZ3022
Bosch SMZ3044
Bosch SMZ3055
Bosch SMZ3077
Bosch SMZ3088
Amana SNAC-700.A COMMERCIAL MICROWAVES
Amana SNAC-700.B COMMERCIAL MICROWAVES
Amana SNAC-7TP.A COMMERCIAL MICROWAVES
Amana SNAC-7TP.B COMMERCIAL MICROWAVES
Amana SNAC700 COMMERCIAL MICROWAVES
Amana SNAC700.C COMMERCIAL MICROWAVES
Amana SNAC700.D COMMERCIAL MICROWAVES
Amana SNAC7TP.003 COMMERCIAL MICROWAVES
Amana SNAC7TP.004 COMMERCIAL MICROWAVES
Amana SNAC7TP.005 COMMERCIAL MICROWAVES
Amana SNAC8LW COMMERCIAL MICROWAVES
Amana SNE26AA RANGE - ELECTRIC STD DELAWARE
Amana SNE26CB RANGE- S/C S/I DDRAFT GAS
Amana SNE26CB RANGE - ELECTRIC STD DELAWARE
Amana SNE26ZZ RANGE- S/C S/I DDRAFT GAS
Amana SNK26AA RANGE- S/C S/I DDRAFT GAS
Amana SNK26AA0 RANGE- S/I STD GAS
Amana SNK26AA5 RANGE- S/I STD GAS
Amana SNK26CB RANGE- S/C S/I DDRAFT GAS
Amana SNK26CB0 RANGE- S/I STD GAS
Amana SNK26CB5 RANGE- S/I STD GAS
Amana SNK26FS RANGE- S/C S/I DDRAFT GAS
Amana SNK26FS0 RANGE- S/I STD GAS
Amana SNK26FS5 RANGE- S/I STD GAS
Amana SNP26AA RANGE- S/I STD GAS
Amana SNP26AA0 RANGE- S/I STD GAS
Amana SNP26AA5 RANGE- S/I STD GAS
Amana SNP26AH0 RANGE- S/I STD GAS
Amana SNP26CB RANGE- S/I STD GAS
Amana SNP26CB0 RANGE- S/I STD GAS
Amana SNP26CB5 RANGE- S/I STD GAS
Amana SNP26ZZ RANGE- S/I STD GAS
Amana SNP26ZZ0 RANGE- S/I STD GAS
Whirlpool SNPA-0 Pasta Maker Stand Mixer Attachment
Amana SP17A REF - SXS/I&W
Amana SP17A-A REF - SXS/I&W
Amana SP17A-AG REF - SXS/I&W
Amana SP17A-C REF - SXS/I&W
Amana SP17G REF - SXS/I&W
Amana SP17G-A REF - SXS/I&W
Amana SP17G-AG REF - SXS/I&W
Amana SP17G-C REF - SXS/I&W
Amana SP17N REF - SXS/I&W
  #2 (permalink)
Old 06-18-2012, 10:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Jeff,
There are two pumps in this dishwasher. The drain pump and the circulation pump. Remove the kick panel and check which pump makes that humming noise. Post the result. Also post the serial number of the dishwasher (FD number).
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 06-18-2012, 11:27 PM
Junior Member
Default Bosch Dishwasher quit running.
Hi Gene,
Thanks for your reply. The serial # is: FD730200037. I did look at tech diagrams I found on the appliancepartspros website (wiring, timing, circuit) and confirmed that the drain pump should run first for about 25 seconds after turning on the unit (this is what we normally hear before water starts entering the unit). But this pump is not running. I did check the voltage at the drain pump after turning the unit on and each of the three terminals (gray, brown, black/white) to ground were showing 115V so power appears to be going to the drain pump but it is not running. No noise at all. The only sound we hear is an electrical clicking/humming which I believe is the timer running. I haven't tried to locate the circulation pump terminals but I don't think they get turned on until the drain pump finishes its initial cycle. I did check the water valve voltage and it shows 0v across its terminal. So if the drain pump has failed, would that mess up the timer and prevent the other "timing" events from firing (i.e. water valve lets water in, circulation pump starts up, etc.).
Thanks again for your help :-)
/jeff
  #4 (permalink)
Old 06-19-2012, 12:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by jalthof@centurytel.net View Post
...I did check the voltage at the drain pump after turning the unit on and each of the three terminals (gray, brown, black/white) to ground were showing 115V so power appears to be going to the drain pump...
Hi Jeff,
This test result is very bad because two of these three wires are neutral and ground so, the readings between them and the ground should not be even close to 115 VAC.
Did you disconnect these wires from the drain pump prior to measure the voltage? If not then redo this test with the wires disconnected and post the results.
__________________
  #5 (permalink)
Old 06-20-2012, 10:29 AM
Junior Member
Default Boschswasher quit running
Hi Gene,
I pulled the wires off of the leads to the drain pump and the brown and white/green and black wires which are the "low side" wires are not connected to ground (i.e. infinite resistance). The brown wire goes to the water solenoid which goes to the float switch and then I'm guessing to ground (I have not confirmed that is the case via continuity testing). I have pulled the drain pump out and tested it by attaching to test cord and plugging into an outlet and it does run. I tested the float switch and it is working. The water solenoid appears to be okay (has some resistance but does have continuity). The black "low side" wire from drain pump goes to a capacitor (don't know how to test it) and the white/green "low side" wire from drain pump goes to High Limit switches (which I'm not sure how to test either). Since neither of these "low side" wires connect to ground (continuity test shows infinite resistance) the "drain pump circuit is not being completed. So could the problem be in the timer switch in that a "return" contact has gone bad and not performing the necessary connection to ground? I removed the black and white/green leads from drain pump motor hoping to see that it would run (that would indicate that the capacitor and/or high limit switches are the problem) but it didn't. I then connected them back to the drain pump and removed the brown lead to see if it would run (that would indicate a problem with the water solenoid and/or float switch) but it didn't. So I believe all of these parts are probably okay and another common path to ground is being prevented by some other failure.
thanks again for your help.
/jeff
  #6 (permalink)
Old 06-20-2012, 01:22 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Jeff,
Since I don't have the wiring diagram for this model, my diagnosis might be look as a guessing, but I would suspect the timer or the push button switch. Also the breakdown diagrams and parts list, we can access, are for a newer model than yous (per the FD number). How much we can trust it?
I would think about a new dishwasher in such situation.
__________________
  #7 (permalink)
Old 06-20-2012, 10:44 PM
Junior Member
Hi Gene,
Well, I took a much closer look at the wire harness that goes from the control panel down the door and into the unit, and as suggested by another blog I found when researching my issue, a wire within the harness had broken from the wear and tear of bending back and forth. The broken wire apparently got to a point where it caused enough sparking to burn/push through the plastic protective wrap. It wasn't easy to see when looking at the wire harness a couple of days ago but after removing another bracket to gain better access to the harness it was obvious there was a problem. I carefully cut the protective covering open enough to look at the bad area and sure enough the green/white wire was 99% broken. I was able cut it completely, strip both ends, and wire nut them together. I got the wires taped up, put everything back together, and my 17-yr old Bosch dishwasher is purring like a kitten once again!!
Thanks again for your help and patience.
Sincerely,
Jeff
  #8 (permalink)
Old 06-21-2012, 12:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Jeff,
Just wanted to say thank you for sharing your diagnosis and repair with us. Your post was very illuminating and instructive.
Thanks again and good luck with your dishwasher.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Dishwasher Quit C Bosch Dishwasher Repair 0 02-21-2012 05:17 PM
Bosch Dishwasher running >4 hrs rjgchi Dishwasher Repair 0 06-27-2011 01:23 PM
KitchenAid dishwasher quit running larrywick Dishwasher Repair 3 11-27-2010 07:30 AM
Bosch Dishwasher Not Running Shiloh376 Dishwasher Repair 1 04-10-2009 05:40 PM
Kenmore Dishwasher Quit running Bob Engelman Dishwasher Repair 6 10-24-2008 10:41 PM
