| » ge profile dishwasher |
LinkBack (1) | Thread Tools | Search this Thread | Display Modes |
Model Number: gsd5134d01ww Brand: GE Age: 1 - 5 years
dishwasher doesn't pump out all of the water. bottom of tub has water left in it. pump has some pressure when dumping.
First check the drain line where it connect to the sink, make sure it is not clogged there, also check if the pump is working, if both things are ok then the problem is the--piston & nut.
The piston & nut is a litttle plastic thing with a spring on it this is located on the inside of the dishwasher at the back this is how you get to it, at the back of the dishwasher on the inside there is a strip of plastic with mesh on it this is held in place with four 1/4 inch screws use a 1/4 nut driver to remove them, lift up and remove the strip, under the strip you will see the piston & nut sometimes you can use your fingers to un screw it if not use a pliers to move it then use your fingers to un screw it, take it to your local parts store or order it from --appliance parts pro--. |
LinkBack to this Thread: http://forum.appliancepartspros.com/dishwasher-repair/4820-ge-profile-dishwasher.html
| Posted By | For | Type | Date |
| Digg / All News, Videos, & Images / Upcoming | This thread | Refback | 01-25-2008 11:35 AM |
| Display Modes | |
| Ge Profile Arctica | nguyenbn | Refrigerator & Freezer Repair | 14 | 08-14-2008 09:47 AM |
| GE Profile washer | jkoz6 | Dishwasher Repair | 1 | 12-21-2007 03:32 PM |
| GE Profile won't run | edroffey | Trash Compactor Repair | 0 | 12-13-2007 11:37 AM |
| GE Profile QPIII | kevlar | Dishwasher Repair | 4 | 12-03-2007 06:54 PM |
| GE Profile Not Getting Water | JeffZ | Dishwasher Repair | 0 | 12-01-2007 01:31 PM |
