| » whirlpool |
A model number may help others help you.
If the unit has a separate drain pump, does it come on? If yes then you probably have a blockage in the drain line. A common spot is where the drain connects to the house plumbing. I am assuming that the drain used to work OK and nothing has been changed with the hook-up.
__________________
| Display Modes | |
