| » Jenn-Air dishwasher won't run |
Model Number: JDB3610AWX Brand: Jenn-Air Age: 1 - 5 years
I started the washer on "light wash" and it made a funny noise when it started filling with water. I canceled the cycle and the washer drained. I restarted it on "normal wash," it started to fill but it would never start the wash cycle, but it will drain. What could be the problem? Thanks for your help.
Does it make any unusual noises?
If it does, can you describe the noise and where it's coming from? Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Remove the bottom panel and check for a slow water leak through the pump which could cause rust to the motor bearings.
In such case you have to order the pump & motor bushing assembly together with the pump seal/impeller kit. If there is nothing wrong then possible a foreign object stuck inside the pimp. - The part number for the pump & motor bushing assembly is AP178769 - The part number for the pump seal/impeller kit is AP178753 Here are the break down diagrams for the Jenn Air dishwasher Model JDB3610AWX Gene.
__________________
Hi gbousa,
What is the model number of the dishwasher? Gene.
__________________
Hi gbousa,
The repairman took the dishwasher apart and found two little pieces of hard plastic that was keeping it from running properly. At first, I couldn't figure out where the plastic came from, but after searching my utensils, etc. I found the cheese grater had broke and the pieces got down in the washer. It cost me $156 to get it fixed, but it works fine now. Good luck. |
| Display Modes | |
| Old Jenn-Air Cooktop | fredringwald | Oven Repair (including Ranges and Cooktops) | 2 | 07-29-2008 11:36 AM |
| Help with old Jenn Air SCE30600W | David0250 | Oven Repair (including Ranges and Cooktops) | 0 | 12-02-2007 10:42 AM |
| Jenn-Air Range issues | crtaffner | Oven Repair (including Ranges and Cooktops) | 0 | 11-11-2007 09:39 AM |
| jenn air stove | jsgt | Oven Repair (including Ranges and Cooktops) | 0 | 10-28-2007 05:12 PM |
| Jenn-Air Wiring | ezra710 | Oven Repair (including Ranges and Cooktops) | 0 | 09-20-2007 09:39 AM |
