| » mid sprayer arm |
Model Number: GSD6900J00WW Brand: GE Age: 5 - 10 years
On the upper rack assbly diagram, the spray holes on the mid spray arm are pointed upward. On a few of the repair posts the pictures supplied by owners the holes are pointed down! Which way is correct? thank you
thank you for that... now if you know why it isn't spinning i need to fix that.
Replacement parts for General Electric GSD6900J00WW Dishwasher | AppliancePartsPros.com Check that it manually spins easily. Check that the angled holes at the ends of the spray arm are clear of debris. Check that it seals OK onto the rear water supply tube. Check/clean the sump and the filter under the bottom spray arm. Check the water fill level. Most units fill to just under the heating element. If unsure you can check it by adding a couple quarts of hot water after a fill. If it now spins OK then low fill is the probable cause. Just be careful to not overfill it.
__________________
| Display Modes | |
| Lower Sprayer Arm | kebbarr | Dishwasher Repair | 1 | 12-31-2010 04:35 AM |
| Mid Sprayer | BLCUSTOMS | Dishwasher Repair | 2 | 11-16-2010 06:13 PM |
| sprayer not spinning | doublet | Dishwasher Repair | 6 | 07-28-2009 08:38 PM |
| Sprayer arm | Motoduc84 | Dishwasher Repair | 0 | 06-05-2009 06:05 PM |
| Bottom sprayer arm wont turn, but top sprayer arm does work | chader | Dishwasher Repair | 0 | 01-12-2009 07:24 AM |
